Old 09-18-2005, 03:01 AM
nmisch nmisch is offline
no power to ignition coil
anyone have any ideas... 1995 ford taurus 3.0
i started my car the other day and it ran for a few seconds and died. i have plenty of fuel pressure, but no spark. im not getting any power to the ignition coil. i looked at a wiring diagram and followed the power from the ignition switch to the fuse panel in the engine compartment. i have fire going into and out of the 10amp fuse... all other fuses good too. from there i didn't physically follow the wire to the coil, but according to the diagram the wire goes straight to the constant control relay module with two splices along the way... one goes to the ignition control module the other to the ignition coil. i checked for power in these three places, none found. i thought i had found the problem, so i ran a new wire just to see what would happen... i had power in all three spots, but when i turn the key i lose all power... what do i check next?
some other things...
upon my initial investigation i found that my diagnostic plug coming from my powertrain control unit had melted on the little pipe connecting my egr valve to the exhaust... (intially i thought that i shorted out my pcu, but why no power to the coil, icm, and the ccrm???) i dont see the relationship in the wiring diagram... which doesnt even seem like its complete...
sometimes the engine wont even crank i just get one click or a series of clicks... should have plenty of power from battery...
sometimes the ccrm and something else (maybe the pcu) makes a hissing noise, is this normal?
any advice would be appreciated...
Old 09-18-2005, 06:36 PM
Re: no power to ignition coil
help please...
where are the mechanics at???
Old 09-18-2005, 08:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
i started my car the other day and it ran for a few seconds and died. i have plenty of fuel pressure, but no spark. im not getting any power to the ignition coil. [snip]
[snip]
Hmmm, a few weeks back (or more) I remember reading someone elses posts where they had a similar situation in which their diagnotic connector was melted and their car wouldn't start. They went to a junkyard and picked up the wiring harness for the diagnostic connector, soldered it in, and it fixed their problem. I don't recall all the details, but you may want to search around for that post.
-Rod
Old 09-18-2005, 08:54 PM
shorod's Avatar
SHO No Mo
Found the thread I was remembering. Read through http://www.automotiveforums.com/vbul...=melted+Taurus
and see if anything helps.
-Rod
Old 09-18-2005, 11:45 PM
thnx shorod... ive been waiting for your reply... tomorrow i think ill start by replacing the diagnostic plug, and then testing the ccrm...
another thing, yesterday my fuel pump was working properly... today it wont turn on.
