Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-17-2005, 12:24 PM
Erik13 Erik13 is offline
Will DOHC head work on a 95 SOHC block?
Got an eclipse I think it has the DOHC 420 motor in it and bought a 95 Neonwith good motor but its a SOHC will the block from the neon match up with the head from the eclipse?
Old 09-17-2005, 04:58 PM
99 Neon R/T 99 Neon R/T is offline
Re: Will DOHC head work on a 95 SOHC block?
If you want to put a dohc head on a sohc here is what you need:But I think it has to be from another neon because of the computer swap.Hope this helps a little.
*DOHC head with cams and valvetrain
*DOHC Intake manifold and gasket
*DOHC exhaust manifold or header or turbo manifold and gasket
*DOHC EGR valve tube and gaskets
*DOHC throttle body gasket (it's different from plastic SOHC manifold)
*DOHC valve cover and gasket
*DOHC cam gears
*DOHC PCM that is compatible with your year of car, 95, 96, or 97-99
*DOHC timing belt
*DOHC timing belt covers (if you want them)
*DOHC timing belt idler pulley on head
*DOHC plastic thermostat housing and gasket
*DOHC upper radiator hose (SOHC may work for some)
*DOHC camshaft position sensor, gasket and wiring pigtail (although I HAVE seen a SOHC sensor bolted to a DOHC motor using only 2 bolts)
*DOHC air cleaner assembly, unless you are using an ICE MAN or similar
*DOHC spark plug wires
*DOHC hard plastic fuel line from metal line to fuel rail (SOHC may work for some)
*Headgasket (should be the same for SOHC and DOHC?)
*Head bolts (can't remember if SOHC and DOHC head bolts are the same, but I think they're different?)
*Anerobic gasket sealer for camshaft caps
*Using dual radiator fans is suggested if you have A/C
*Extend the 3 CTS (coolant temp sensor) wires so that they reach the new CTS location engine here
If it aint broke fix it till it is.
Old 09-20-2005, 09:22 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
The neon engine is not a 420a engine. They are completely different engines. They will not swap at all.
Old 09-24-2005, 04:44 PM
pinkslipRT pinkslipRT is offline
Banned
neon engine code = 4DRE FOR DOHC OR 4SRE FOR SOHC
Old 09-24-2005, 05:50 PM
Re: Re: Will DOHC head work on a 95 SOHC block?
The correct "build sheet" engine codes for the various engines are
DOHC - ECC
SOHC - ECB
Magnum - ECH
Mitsu - 420A
Plus you guys are messing up the proposed "D4RE" etc. by mixing up the order.
Old 09-24-2005, 05:52 PM
Banned
?????mixing up the purposed order?
Old 09-24-2005, 06:28 PM
It would be D4RE, not 4DRE.
Old 09-24-2005, 08:28 PM
Banned
got ya hadnt realized i spelt it wrong
