Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 09-17-2005, 10:22 AM
joemay00 joemay00 is offline
Unhappy GMC Envoy XUV air compressor/pump
A few weeks ago I was using the pump (which is awesome)when it just shut off. It was only operating for about 15 sec which means it was not the safety feature that turned it off. And since then it won't turn on when I use the botton in the back but the auto load leveling still works fine. I couldn't find any fuses in the book that were specific to the air compressor/pump. Any ideas?
Old 01-03-2006, 05:55 PM
Rockhaven Rockhaven is offline
Re: GMC Envoy XUV air compressor/pump
I have the exact opposite problem with my 03 Envoys air suspension. The auxilary port works fine but the air bags won't pump up. There are three different codes that can be present to determine the problem. When you start your vehicle look at the auxillary switch in the back. it has a light on it, it will flash one-long pause-one. this means it is code one. It will do the same for two, two quick flashes-long pause etc. as well as three. Code three is for the right rear sensor and code two is for the left rear sensor. If either one fails it will automatically default to the next sensor, which means the load levelling will still work. Code one means that the eeprom needs to be reprogrammed. Hope this may help. Still trying to figure mine out. No codes on mine.
