Old 09-17-2005, 09:59 AM
Ryan066 Ryan066 is offline
Knock from 3.1 L v6... Plz Help
I am at a lose...
this is in noise I recorded from a 1993 Pontiac Sunbird 3.1 v6 270K... its the knock/rattle in the video (turn your speakers up) and
I need help finding it... it sounds like its coming from the exhaust but then it sounds like a colapsed lifter/broken valve spring.
its coming from the passengers side of the engine.
thanks.. any help is appreciated.
to download:
http://rapidshare.de/files/5206980/knockrattle.mpg.html
hit the free tab near the bottom of the page
and it will say "Download-Ticket reserved. Please wait XX seconds."
then just wait and then it will say: "DOwnload: Knockrattle"
and click
use winamp to listen to it or any other media player.
THANKS
Old 09-17-2005, 02:21 PM
Mod'd_Cav Mod'd_Cav is offline
Re: Knock from 3.1 L v6... Plz Help
id get that to the shop quick or open take the valve cover off yourself cuz if you keep driving that thing around yourself your gonna end up with a nice decent sized hole in your cover...and if your really lucky..your hood...open your valve cover and inspect for anything loose..its prolly a rocker arm or a rod..but the point being..dont drive it..i knew a guy that had a Z24 with that same noise and his rod shot thru his hood leaving a hole on the top of his engine the size of a tennisball
by the way...right on with getting a audio clip to let ppl hear about your problem...really makes it easier when someone makes a thread and goes "i have a sound..its a rattle that sounds like it comes from the front of the car....any ideas?"
hey check it out...i have a twin haha
only subaru style rims look better
Old 09-17-2005, 02:50 PM
Re: Re: Knock from 3.1 L v6... Plz Help
oh yeah for sure... it's sitting in my g-rage now I drive it in and out every so often but thats all.
it's not insured/safetied or legal so its not being driven. my plans were to fix it and sell it.
I took the front cover off to see if any of the valve springs or push rods were loose/broken but that seemed fine...
but I wanna get a better idea of what it is because when i take it apart then I cant hear it run.. and if its just a bolt or something stupid and i have to redo the engine and doesnt get rid of the sound then its going to be rough.
edit::: oh yeah, it was my brothers car and it was leaking very bad PS fluid so he took it in and said that it would cost 400 to replace the PS line. so the mechanic said its not worth it because your motor is no good.
btw I replaced the line myself for 60 bucks so I dunno if I can trust this mechanic
edit::: shit yeah forogt to say it is LOUDest at 2100 RPM... at about 5000 RPM it is pretty much not there.
Old 09-17-2005, 09:13 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
wow, i'd like to see that hole.. he'd have to shoot the piston completey through the head of the motor.. And i'm not seeing that happen.. nor have I heard of it happening
with that mileage I wouldn't doubt its rod knock, but like you said at 5500rpms its non exsitent.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 09-18-2005, 02:21 AM
the rod pretty exploded thru the valve cover..it can happen..its like a retaining pin coming loose in a transmission and taking out half the transmission pan...it can happen..its not just the piece alone...you have to think of the pressure these parts are being backed up with when blowing out of a motor
Old 09-18-2005, 02:27 AM
pre98zetec's Avatar
the valvecover is attached to the head, the head is attached to the block (which has the pistons-rods-crank in it. the rod and pitons would have to "explode" through the head- THEN the valve cover-. 99% of the time you throw a rod through the oil pan or through the side of the block.
-Josh-
Old 09-18-2005, 06:20 AM
yeah I seen a piston shot through the top of a motorcycle.. 15000 RPM .. blew off the guys hand.
Old 09-18-2005, 12:47 PM
pre98zetec's Avatar
motorcycles are totally different
-Josh-
Old 09-18-2005, 05:28 PM
same concept of pistons flying up through the engine lol
Old 09-18-2005, 05:56 PM
pre98zetec's Avatar
not quite
-Josh-
Old 09-18-2005, 07:03 PM
w/e you say bud.. now lets get back on topic.
