Old 09-17-2005, 08:44 AM
mhogan7749 mhogan7749 is offline
03 Tauras Will Not Start
I started my 03 Tauras, it started great. I was letting it warm up and it shut off. As if someone shut the ignition off. Now when I turn the key nothing happens, does not turn over, no click. The battery is strong and all the fuses are ok.
Any ideas?
Thanks
Old 09-18-2005, 12:08 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 03 Tauras Will Not Start
Do all the interior lights work when the door is open? Do the headlights work? Maybe your battery cable(s) are loose and/or corroded.
-Rod
Old 09-18-2005, 07:38 AM
Re: Re: 03 Tauras Will Not Start
-Rod
All other electrical components work great. Only the ignition is dead.
Mike
Old 09-18-2005, 08:42 PM
shorod's Avatar
SHO No Mo
I think the next thing I'd check is for voltage at the starter/solenoid.
Can you get to the starter motor and solenoid and check the solenoid for voltage while someone else attempts to start the car?
-Rod
