Old 09-17-2005, 01:40 AM
Johannes Johannes is offline
Banned
Bass Test Tones
Can playing test tones like the one on this site: http://kan3.freeservers.com/ ever harm a subwoofer if you play really low ones?
Old 09-17-2005, 02:01 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Bass Test Tones
If you push it beyond its mechanical (bottoming out) or thermal (voice coil melts) limits then yes, otherwise no.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-17-2005, 12:11 PM
Banned
I'm not talking about giving it way too much power with the gain way up or anything like that... I mean playing a 10hz test tone on a subwoofer that's only rated for 15hz and up, something like that.
Old 09-17-2005, 12:58 PM
sr20de4evr's Avatar
Re: Bass Test Tones
no that won't cause any problems
It's just a voltage that changes over time, as long as you don't exceed the mechanical or thermal limits of the speaker then it doesn't care what you're feeding it
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-17-2005, 08:43 PM
Banned
Re: Bass Test Tones
Okay, kinda what I figured... thanks.
Old 09-17-2005, 08:52 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Bass Test Tones
but remember the lower the frequincy the longer the voltage stays close to peak, so at least play them at -3dB to be on the safe side, especailly since a lot of amps clip just because the circutry cant handle the current peaks when frequincies drop really low.
Old 09-17-2005, 10:56 PM
Banned
What exactly do you mean by -3db... are you referring to adjusting it on the head unit?
I played them, you can only really hear them around 30hz+, otherwise you can't really hear it too well, it's just kind of a popping...
It's like the bass in Snoop Dogg's "Suited and Booted" and about a million other songs... low frequencies sound awesome, I really should get a good setup!
Old 09-18-2005, 12:53 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Re: Bass Test Tones
NO a 10 Hz sine wave has exactly the same duty cycle as a 5KHz sine wave if the peak level is the same. What makes the voltage (power) stay near the rails is called clipping.
Old 09-18-2005, 10:25 AM
CBFryman's Avatar
Banned
Re: Bass Test Tones
paul, i wasnt refering to staying AT peak longer i was refering to staying at higher voltage for a longer duration... over a set period of time the ammount of time each spends at any particular amplitude is the same HOWEVER the lower the frequincy the less often the amplitude changes dramatically.
see pictures, the first is a 10hz signal and the next a 5kHz signal. also look at the time elapsed at the top.
and BTW
-3dB means it is recorded at 1/2 amplitude.
Old 09-18-2005, 01:12 PM
sr20de4evr's Avatar
Re: Bass Test Tones
You hear popping below 30hz? That's the sub bottoming out, that's what I was warning you against in my first post. Are the subs ported? I couldn't see crappy output and high excursion below 30hz unless the subs were in a high-tuned ported box.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-18-2005, 01:15 PM
sr20de4evr's Avatar
and BTW
We see what you're saying, but your argument makes no sense, the speaker will behave the same way with either of those (except the sub's inductance will limit the output of the 5khz wave), as will the amp.
And -3dB is 70% of the original amplitude, half would be -6dB.
'01 Black Sentra SE
'05 Silver WRX STi
Old 09-24-2005, 12:22 AM
Banned
Re: Bass Test Tones
It's a sealed box... and it really isn't quite a popping noise, more like the sub moving in and out really fast, kind of a thumping noise...
