Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-16-2005, 10:29 PM
Dan XVI Dan XVI is offline
Send a message via AIM to Dan XVI
Exhaust install question
Hey guys, Im having some problems installing the 2.5" Tsudo Fireball catback exhaust I bought off of eBay..... On the stock exhaust, there is a sensor after the cat, but on the exhaust I purchased, there is no place to install this, any ideas? Thanks for any help in advance.
1996 Talon NA 5 speed
2.5" Tsudo Catback 3.5" tip
Rear End Eclipse Conversion
Coming soon:
Ebay Intake
Header
UDP
Old 09-17-2005, 04:45 AM
SLoe's Avatar
SLoe SLoe is offline
Wrap the sensor in aluminum foil, and wire tie it up out of the way.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 09-17-2005, 09:33 AM
That won't cause any problems? I get the feeling that sensor is there for a reason?
Coming soon:
Ebay Intake
Header
UDP
Old 09-17-2005, 10:24 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Exhaust install question
once you get your exhaust put on take it to an exhaust shop and they should be able to put that sensor back in
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-17-2005, 07:25 PM
SLoe's Avatar
No, that sensor is there to tell your computer that your cat is working. If your cat is not working properly, then that sensor will cause your check engine light to come on. Does your state have emissions checks? If not I would ditch the cat anyway. Or as silvreclipse says you can take it to the shop and they will put it in.
Old 09-17-2005, 11:22 PM
Holset powered 420a
his car is a nonturbo so he should keep the cat on
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-18-2005, 04:59 AM
SLoe's Avatar
Re: Re: Exhaust install question
????? Why would you say that?????
Old 09-18-2005, 09:02 AM
I live in NJ, so the cat definitely has to stay on. I thought that if I removed that sensor the fuel ratio would be off, guess I was wrong.
Coming soon:
Ebay Intake
Header
UDP
Old 09-19-2005, 07:32 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
No... the sensor doesnt adjust or do anything. Its basically just an on/off sensor. If cat is fine, its on... if cat is bad, its off. Which causes a CEL. Keep the cat on. Won't get much performance. And since you have emmissions, definitly keep it on. There's no need to get it done until you get called up for the emmissions testing anyways. I got emmissions, and Ive yet to install the second one yet. I wont until the day I go to get it tested, but until then, more money elsewhere. Goodluck.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-19-2005, 07:37 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
All OBD2 vehicles must have o2 sensors after every cat. Follow the instructions from this link to eliminate the rear o2. http://www.vfaq.com/mods/O2bypass.html
DSM geek
