Old 09-16-2005, 08:57 PM
01 stang12321 01 stang12321 is offline
change oil
i have a 01 stang and it has 40k miles and i havent changed the oil. i probaly will in a few days so is that bad for it at all?
Old 09-16-2005, 09:06 PM
b3warnick b3warnick is offline
Who knows when it was last changed? Could've been just 1 or 2 thousand miles ago. Could've been 7, 8, 9 thousand miles ago. I'd change it now, and start keepin' tabs on it from now on. Lots a guys change it at every 3,500 miles. I change mine at 5,000 miles. (V-8)
Not knowin' what was it in before, you might want to ask your mechanic whats a good 'neutral' oil that your car will adapt to.
Old 09-17-2005, 02:12 AM
Jim Adams Jim Adams is offline
I agree with b3warnick about the changing oil and tabs on the intervals
I would do one more thing though,,,if you know or have an idea how long its been since last change and it has been over 8000 since its been changed then you may want to do a back to back change,,,this means do a change using 10/40 and run her for 100 miles to loosen up and heat up the engine and all its components. The change it again when she is hot and let it drain for a while ie: 3 hrs to let all dirty oil drain completely, then put for summer use a good 10/40 oil like Valvoline and in winter use probably same thing,,the factory prob calls for 10/30 or 5/30 but after 40k you tend to get clearences in the engine pending on how it was driven and 10/30 just doesnt take up the clearences . Good luck!!
Old 09-17-2005, 03:13 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: change oil
I change mine @ 20,000 miles, but I use Amsoil.
If you are saying that you have waited 40,000 to change your oil, you have some major issues.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-22-2005, 05:45 PM
cllamont cllamont is offline
I swear by synthetic oil. Mobil has a new one that lasts 15,000 miles - sounds like you could use this if you let those many miles roll up before changing it.
Old 09-29-2005, 08:12 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: change oil
I change my oil ever 2500 miles. There's just something about letting oil stay in my motor for a lone period of time. Even if it is state of the art oil and does not breakdown, it still gets dirty all the same.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 10-01-2005, 12:17 AM
~manuel~ ~manuel~ is offline
Re: change oil
just make sure you install a quality filter that can filter at that 10-20 micron level.all those cheap oil filters dont cut it.they only filter down to 50 microns and a large percent of engine wear is caused by particles much smaller than 50 microns.
