Old 09-16-2005, 05:47 PM
tubjub's Avatar
tubjub tubjub is offline
Send a message via ICQ to tubjub Send a message via AIM to tubjub Send a message via MSN to tubjub Send a message via Yahoo to tubjub
collapsed lifter
89 blazer ... 2wd ... automatic 4.3L ....
my buddy's sister ran it about 1.5 - 2 quarts low on oil and its got well over 200k on it.
she brought it home today complaining of a tapping noise coming from the engine ... we filled it back up with some 10w30 and its still tapping.... i'm thinking a collapsed lifter ??? is there any cheap way to get it pumped back up ? i've heard of gunk flush, tranny fluid, brake fluid, but i'm not dumping anything in there that might ruin it... oil hasn't been changed for awhile eiether. the poor girl has to have this thing to drive to work and i don't wanna tell her to just drive it for fear of wiping out the camshaft or pullin the lifter out of the pocket on the rocker...
blazerLT, i know ur around somewheres, you helped me in the past and i'd apprecieate some more advice... lol thanks
This is your life and its ending one minute at a time...
Old 09-16-2005, 05:59 PM
Joshua M. Smith Joshua M. Smith is offline
Send a message via ICQ to Joshua M. Smith Send a message via Yahoo to Joshua M. Smith
Re: collapsed lifter
When rebuilding motors one must pump the new lifters up manually. Thus, they make a tool for this.
Go to Autozone and ask for their oil pump spinner, or whatever they're calling it these days. Go home, pull the valve covers and distributor (mark it). Put the spinner on a drill and then lower it into the distributor hole. Run it until you see oil spurting out of the pushrods.
This may pump it up. Or it may not if the lifter's bad. Check for bent pushrods as well. They may not spurt oil if bent too badly. It's up to you if you want to try it. The tool's rented so all you're out is money for valve cover gaskets, not much at all.
I wouldn't be dumping stuff in your oil to try to make it go away. It doesn't work, at least not for long.
Josh <><
Old 09-16-2005, 06:28 PM
tubjub's Avatar
hydraulic roller lifters are $13 apiece at advance auto...
oh well the UIM and valve covers are coming off as we speak.
thanks
Old 09-17-2005, 12:29 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
NO!
2 qts low will NOT collapse the system.
Throw a bottle of gunk flush in there, idle for 30 minutes and then do a complete oil change with a new NON FRAM oil filter.
Telling someone to rip things apart because of this is premature.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-17-2005, 02:04 AM
tubjub's Avatar
well its already said and done with and the lifter was in fact trashed... no hope for it (honestly) took abt 3 hours but its all done now and everything's back to normal... we DID flush it because the lifter valley and erronous hardware and parts were incredibly nasty. scraped out loads and loads of a grease-like substance that seemed to be the old "valvoline" myth... lol
but hey i'll remember that for the future just for starters...
had some old boy from kentucky come over and look at it and he just started rippin it apart and 3 hrs later its done... lol
Old 09-18-2005, 06:13 AM
BlazerLT's Avatar
AF -Advisor
It only took 3 hours?
Wow.....
Shoot, did oyu take pictures?
Also, you should still do a flush bro, even though you scraped it, the stuff is still in there.
Old 09-18-2005, 02:35 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Re: collapsed lifter
Wow.....
Wow that is fast! BlazerLT, I believe he said he did flush it.....
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-19-2005, 11:29 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: collapsed lifter
But, he should still flush it again to get rid of the remaining crud he loosened up when scaping the old stuff off.
Old 09-19-2005, 04:09 PM
Re: Re: Re: Re: collapsed lifter
Ah I catch what you are laying down now. I used the gunk stuff myself and it worked pretty well I think.
K&N Air Filter
Old 09-25-2005, 05:10 PM
tubjub's Avatar
sorry guys kinda forgot about ya there... yeah it took about 3 hours give or take a lil bit... we flushed it, put new oil in, drove it about 50 miles, flushed it again, put new oil in it again and it seems to be alright, smooth and quiet as hell... didn't take pix becase i was dirty as hell and the camera phone doesn't operate too well in low light ... but yeah it was a chore ... lol
Old 09-25-2005, 08:10 PM
Yea but I am sure you felt pretty satisfied after it was done. I can't wait to rip an engine apart and go crazy in there!
K&N Air Filter
Old 09-26-2005, 01:50 AM
NO!
I have to disagree. I don't believe in throwing in engine flush (old school here). Even if it works, the lifter will collapse again. You sorta' made my point: 2 quarts will not collapse a lifter. It is therefore time to replace the thing if it won't pump up using a priming tool.
I'll just agree to disagree on this if you will. We're both trying to go the same place with different methods.
Josh <><
Old 09-26-2005, 01:56 AM
BlazerLT's Avatar
AF -Advisor
Fair enough.
Old 09-28-2005, 06:00 PM
tubjub's Avatar
did i mention the collapsed lifter was REPLACED ? lol
Old 09-29-2005, 03:42 AM
Hello,
Yes you did. BlazerLT and I were just sharing some mechanics' banter is all.
Josh <><
1989 Chevy/GMC "Blimmy," 4.3 motor, the only motor I've ever had that I've left stock
1993 Olds Bravada with the works.
My firearms board, in association with Hipowers and Handguns.com:Click Here
