| Off-Topic Talk about anything other than cars. |
quick question(please respond ASAP cause I wanna go to lowes)
I always have problems boost testing my car. Has anyone ever used like an electric compressor? Mine puts out a constant psi, but isn't adjustable, so it doesn't seem like it's putting in enough air to pressurize the system. The most I can ever my boost guage to hold is 1psi. I've tried a bike pump too, but I think you run into the same problem not being able to compress enough air into your system.
Is it possible that I have a leak bad enough to allow it to hold only 1 psi, or should I run out to lowes and pick up a tank that'll flow, say, a constant 20 psi? I've done the vaccum line elimination thing, resurfaced my throttle plate elbow where the UICP bolts to the manifold(with gasket of course), I've just replaced all my injectors with all new O rings and seals, and a new gasket going from my LICP to my stock IC. Now could there possibly be a leak that big anywhere?! Or do I need a better compressor.
1990 Eagle Talon TSI AWD MOD LIST: ______________________ Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel |
Re: quick question(please respond ASAP cause I wanna go to lowes)
It could be a leak that big. Did you hear any hissing once you stopped compressing the air? If not, then the leak may be so big that its getting out of the system before you even have time to stop compressing it... Also, do you have any problem building boost when you drive it?
-Brian
Re: Re: quick question(please respond ASAP cause I wanna go to lowes)
When i leak tested mine i used a air tank and it worked fine. To make sure i did not have any small leaks i used a spray bottle of soapy water, but that does not sound like your problem. Your problem sounds big. GL man
Current Cars 2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod. 2003 Grand AM GT - official beater car for the winter lol ---------------------------------------------------- 95 TSI AWD [email protected] (T-25) Now fully Modded engine with 3,560 miles on it.SOLD |
You are right in thinking that you need a large volume of air available to build pressure in the intake system. A bike pump and small electric tire pumps are not going to work. At the minimum use one of the small tanks that can be filled at a gas station's air compressor for example. That can provide enough air volume and pressure to do a meaningfull test. Big leaks are tough to find though since the tank is still relatively small and can run out quick. Even with my 30 gallon compressor I have had leaks big enough to empty it before I found the problem. I eventually made a tester that has a air hose quick disconnect on it rather than a tire valve, since the tire valve was much smaller than some of the leaks I have had
But you get the idea. Good luck.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
I have no idea how people get a good test with a bike pump, unless they don't have a massive FMIC with large IC piping to fill and there are no leaks to find
It's also important that the pump/tank/whatever be silent so you can hear leaks. You don't need a regulator if you "regulate" it yourself. It takes time to move air through a shraeder valve, so just watch the guage and let off at the appropriate time. If you use a quick disconnect like I mentioned for high flow rates, then you would need a regulator.
