Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-12-2002, 08:47 AM
ex2fast4u ex2fast4u is offline
Send a message via AIM to ex2fast4u
ZEX Nitrous kits: good? bad? otherwise, Experiences
I recently saw a 95 civic with a basicaly stock 1.6L SOHC engine, running a ZEX dry kit, with a 55hp injector. I have a 98' ex, and with a swap to a gsr engine on the horizon, I would like to be ready to destroy the competition. Anyways, for now I was wondering are the ZEX kits as good as they look? If I go with the kit, would you reccomend the colder plugs that they have available? I also would like to get the Maximizer kit, that will give me another bottle and the fittings. Thanks for the info guys
*Chris*
Old 05-12-2002, 11:25 AM
silvercivicgrl's Avatar
silvercivicgrl silvercivicgrl is offline
Send a message via AIM to silvercivicgrl
zex kits are nice alot of my friend have them but they dont use them responsibly. if u put zex on a basically stock non built up engine and if u spray like everyday yea expect to have problems. personally i wouldnt put zex on my ex engine but a gsr should be ok. now im not an expert on this but common sense tells me u might want to build up some internals. my friend with a maxima put zex on his car, and my friend with a b16a (i dun remember the # after the a whatever) he put it in and well about blew himself up. the engine was old anyways.
personally id save up for a turbo. as the saying goes nitrous is the poor mans turbo
-ashley
i love my boyfriend ^_^
Old 05-12-2002, 12:00 PM
98civicex 98civicex is offline
i've heard alot of good stuff about the zex kit. the only part i don't like about the kit is that when the system is armed, it will spray at wide open throttle, which is set at a certain rpm. other than that the system is the safest and pretty cheap too. just remember the %50 rule with your engine and nos. 50% of your overall hp is safe.
good luck
98 civic ex
-former ph member since may 00-
wings west type w kit
2.5" spring springs
aem cold air
apexi ws exhaust
apr aluminum wing
h4 headlights
clear tails
indiglo guages
dc short shifter
type r shift knob
autometer phantom 5" tach
eclipse 7002
eclipse sound processor
eclipse 8 disc changer
playstation 2
Old 05-12-2002, 12:18 PM
good luck
yes zex is very safe too. it will only spray when you floor it (thats the best way to describe it) our of all the n2o systems that would be the one i would get.
-ashley
Old 05-12-2002, 03:20 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
i prefer the NX system... much safer considering dry mist is a very good way to lean detonate a cylinder
Old 05-13-2002, 10:18 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
Any kit will pray when you're at WOT, as long as you hook it up that way. I think a lot of people dont do it the right way to hoook it up and have problems.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 05-13-2002, 12:39 PM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
I saw an early nineties model civic on horsepower TV the other day and they put the ZEX system on that car. They said why they had choosen this system, but I can't remember why. All I know is that they had choosen this system above all others because it was the best system for the money. Other than the ZEX system, all they added was an ignition system, cold air intake, and of course all of the little things (high power plug wires, exhaust, a few others). The kit came with a 55 shot and a 75 shot. They used the 55.
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 05-13-2002, 03:34 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Actually the Nitrous would be safer on an D16Z6 EX motor over a GSR motor. The comp ratio is much lower on our EX motors then it is on a GSR. The EX motors I have seen work very well with F/I apps. Those D16 Series motor are strong fuckers that for sure. Now the tranny handling that much horse is another story.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-29-2002, 07:26 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Zex kit.
I got my zex kit and installed on my d16 powered 91 hatch about a month ago, i love it. I've had no problems with it, but i dont spray it all the time either, I used the 55 HP jets .
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-30-2002, 08:03 PM
ViGGa2LO ViGGa2LO is offline
Send a message via AIM to ViGGa2LO
If you get that ZEX i would also consider putting a performance intake manifold in because after a while of spraying you will blow.
Old 05-31-2002, 10:02 AM
MD99SiR's Avatar
MD99SiR MD99SiR is offline
Send a message via AIM to MD99SiR
If you want to just have Nitrous then Zex is the way to go, or if you are new the the street racing/import scene. If you plan to build up your motor and run with the big dogs then you might want to invest in something a little more powerful like NX or NOS. The Zex kit is the playschool of nitrous. It's so safe and easy to install a child could do it. The only disadvantage of it is you can only go up to 75hp jets before you have to get a new system because that's all the Zex kits go up to. So if you do build up your motor and want to use nitrous you'll have to buy a new kit. But for now Zex is pretty good, colder plugs, and invest in a bottle warmer, pressure gauge and maybe remote bottle opener. Peace
99 Civic SiR
Greddy EVO
AEM CAI
Sportline Springs
17" Enkei RS7 rims in Bronze
Nitto Neo Gen 205/40/17 tires
Red Carbon Fiber Hood
NX kit 35 shot for now, going to up it to a 50
Sparco Black/Red Torrino Racing Seat
20% Window and sunroof tint
Old 06-01-2002, 05:55 AM
Redlyne Redlyne is offline
Just wondering, is it necessary to have a fuel pressure regulator to boost up the fuel pressure for the zex kit, so it doesn't run as lean, or does the control unit from the zex kit already takes care of that?
