Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-16-2005, 11:11 AM
kevin2811 kevin2811 is offline
95 3.8 a/c problem
What would cause the a/c to only blow out the defrost vents?
Old 09-20-2005, 11:13 PM
MustangMan1995 MustangMan1995 is offline
Re: 95 3.8 a/c problem
I have the same car and just fixed the same problem. The switch that directs airflow in your heat a/c system uses vacuum. If you look under the hood on the driver side right near the firewall there is a vacuum distribution block there. One is marked a/c(third one down). Check to see if the line is cracked mine was. if not right there then trace that vacuum line till you find the leak.
Old 09-21-2005, 11:13 AM
Thanks for the help. I actually checked that very thing that day and the vacuum line was cracked and broken in two different spots. Thanks again.
