Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-16-2005, 11:07 AM
paligap paligap is offline
Angry leak under dash
hey guys,
i have a 90 teg and every time it rains hard i get a leak under the dash on the passenger side.i heard that it could be my blower motor because when i turn my heater on, i notice more water dripping. how can i fix this and where is the blower motor and what does it look like? thanks for any input on this.....
Old 09-16-2005, 01:01 PM
mpumas mpumas is offline
Re: leak under dash
Does it leak more when you have the air conditioning on? It could be the windshield sealing, antifreeze from a leaking heater radiator, plugged drain hose from under the evaparator. Need to examine what the fluid is.
Old 09-16-2005, 01:54 PM
the fluid is H2O because it only happens when it rains,ive inspected the fluid and its water...
Old 09-17-2005, 02:45 AM
Re: leak under dash
OK. I would suspect a leaking windshied seal. The test for this is to put a soapy solution on the outside of the window along the edges all the way around the window. From the inside, using a air hose, blow air at no more then 15 psi all around the seal and look for bubbles.
Old 09-18-2005, 10:07 PM
Re: leak under dash
ive also noticed that itdrips when it rains hard, but when i turn on my heater on, the water pours out for a bit and then drips..
Old 09-19-2005, 06:11 AM
Copytech99 Copytech99 is offline
Re: leak under dash
Did you find the blower motor ? It should be behind the glovebox. The motor should have 3 mounting screws and a couple of wires.
Is the water dripping/running from heater outlets ??
Old 09-19-2005, 11:28 AM
Re: leak under dash
If it is a leak from the heat exchanger, the fluid leaking would be antifreeze. However, there is a moisture collection pan under the airconditioning evaparator which has a drain to the motor compartment I think. It may be plugged. Find that hose and blow air in to clear any obsructions.
Old 09-19-2005, 08:04 PM
Re: leak under dash
i dont have a/c on this car, and is the blower motor inder the hood or behind the dash.the water doesnt leak from the vents, just from uder the glove box
Old 09-20-2005, 12:53 AM
Re: leak under dash
I hope you have antifreeze in the radiator and if you do and what is dripping is water, it is coming from outside the car. The blower motor is under the dash. Back to my earlier post to check the windshield for leaks using compressed air.
