Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 09-16-2005, 09:39 AM
prophetecks prophetecks is offline
Angry 1994 jETTA !!!!!!!!!!!!!!!!!HELP NOW!!!!!!!!!
Ok This Hasd Been A On Going Problem ....sooo My Car It'll Start Cold But When It Warms Up And I Shut It Off It Won;t Start I Replaced The Fuel Pump Soo Does Anyone Know The Problem?????????????????.....
Old 09-16-2005, 09:33 PM
boschmann boschmann is offline
Re: 1994 jETTA !!!!!!!!!!!!!!!!!HELP NOW!!!!!!!!!
Pull the coil wire when it won't start & see if you have spark while cranking.
Old 09-16-2005, 09:40 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
there is an update technical bulletin for this which involves installing a hot start relay between battery and starter. It allows full battery voltage to reach starter.
also starter solenoids can overheat causing the contacts not to touch
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
