Old 09-16-2005, 08:54 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
EGR Valve question
I am not having trouble with My EGR valve (Knock on wood).
I have owned 4 different Blazer/Jimmy Vehicles (an 89, 93, 2000, and a 2001) all with 4.3L engines, and have NEVER had to replace, clean or repair the EGR Valve on any of them, but it sure seems like it is an epidemic, But here's my question.
Is the carboned up EGR valve a reminant or resultant side effect from other problems,
or
is it a result of straying away from stock components, like beefed up performace components
or
Is it due to the local gasolines and/or additives that we use
or
is it simply the operating environment that the engine is in (Like the warm Arizona weather vs the colder Canadian winters)?
Post your theories!
Old 09-16-2005, 05:38 PM
JA no Y's Avatar
JA no Y JA no Y is offline
yes
Old 09-18-2005, 10:48 AM
Big Tall Dumb Ass
Re: EGR Valve question
Originally Posted by JA no Y
yes
O.K. I get it now!
Come on you guys, Instead of swapping these things out every month or cleaning them as often as you brush your teeth, we ought to figure out why!
Old 09-18-2005, 12:38 PM
Cailen Cailen is offline
Just a guess, but wouldn't EGR carbonation be caused by an incomplete/dirty burn? ie excess fuel (I'm thinking leaking fuel pressure regulator and the like here), bad spark plugs/wires/cap/rotor, incorrectly gapped plugs, etc
Old 09-19-2005, 10:12 AM
herkyhawki herkyhawki is offline
Bad CPI or Fuel Pressure Regulator put too much fuel in and cause the excess carbon that shows up as an EGR problem.
Old 09-19-2005, 10:36 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, excess fuel is the cause.
1998-1999+ have no EGR valve.
You only see most valve problems with the CPI injection system.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-19-2005, 07:59 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
So my 98LT does "NOT" have an EGR valve?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-19-2005, 08:21 PM
blazee's Avatar
blazee blazee is offline
Problem?
My 98 has one.
Old 09-20-2005, 08:19 AM
Big Tall Dumb Ass
So when the engine is burning too rich and the on-board computer system cannot lean out the problem, are you supposed to see a check engine light or get a code?
When my 93 lost the CPI and nut kit, I never got a light or a code. I just started getting 200 miles per tank of gas instead of 330 miles per tank, a very rough idle, and poor performance. But I must have caught it before I carboned up the EGR valve.
Old 09-20-2005, 01:53 PM
BlazerLT's Avatar
AF -Advisor
After a certain year, it went completely internal for the EGR.
1998 was I think the last year for any type of external EGR valve.
Yours is not the same as the 1994-1997 EGR valves though.
Old 09-20-2005, 01:57 PM
Big Tall Dumb Ass
Re: Re: EGR Valve question
I was going to say, GMpartsdirect.com shows An EGR Valve for my 2000 Jimmy, but it also shows a different part number for earlier models.
Old 09-20-2005, 04:23 PM
Ok so does that mean I can work on this EGR valve myself if something gets clogged and carbonized or is this something I need not worry about? You learn something new every day folks! The problem is retaining it!
K&N Air Filter
Old 09-20-2005, 06:43 PM
BlazerLT's Avatar
AF -Advisor
there are very few EGR failures with your model year.
Old 09-20-2005, 07:35 PM
Great! Good thing to know. Thank you
K&N Air Filter
