Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
View Poll Results: Which battery is best for 2002 Grand Cherokee?
Stock 650 CCA 1 33.33%
Spiral Cell 750CCA 1 33.33%
Standard but 850CCA 1 33.33%
Voters: 3. You may not vote on this poll
Old 09-16-2005, 07:53 AM
sseguin sseguin is offline
Battery advice
Hi, i have the stock 650 Cold Cranking Amps battery in my Grand Cherokee 2002. Would i see an improvement in starting and cold weather performance as far as starting if i bought a Spiral Cell battery that's rated at 750CCA? What about a normal battery that is rated at 850CCA? Any other advice?
Thanks
Old 09-16-2005, 01:18 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Battery advice
Where do you live? Alaska or Canada, you might want to go with more amps, unless the owner's manual says otherwise.
If you're in the southern parts of the US, you probably don't need all that extra.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-16-2005, 03:07 PM
Re: Re: Battery advice
I'm in Ottawa. seems like i'm only able to get a conventional battery for the size that my car can accomodate physically.
I found a 1040 Cranking, 880 Cold Cranking Amp battery.
Compared to my current stock one of
865 Crank, 650 Cold Cranking.
Making a change to the above battery would i get a easier start in warm weather and cold? OR am i just wasting $140 CDN?
Old 09-17-2005, 11:45 AM
JDPascal JDPascal is offline
Re: Re: Re: Battery advice
The CCA of the battery really only affects the cold weather cranking time that you have to start the vehicle. Warm weather starting is pretty much unaffected unless you have the habit of leaving the lights on and draining the battery.
With your winter temp minimums of about -15C, a quality battery of about 700 to 800 CCA will do you. I got a smokin deal from the dealer for the MOPOR replacement battery. It is a 700 CCA rated unit and it works great for me with our -40C minimum winter temps. Your winter starting reliability will be helped more by making sure that the terminals are clean, the starter/charging sytem is in good shape and using a synthetic 5w30 or 0w30 oil (which is what I use) than the difference of 150 or so points in the CCA rating of the battery.
You should be able to find a good battery within that CCA rating range for around $90. A price of $140 seems a little on the high side to me.
JD
