Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-16-2005, 01:08 AM
humpty dumpty humpty dumpty is offline
Unhappy cat conv=tranny problems?
HELP!
If anyone can clue me in on wtf is going on, I'll be eternally indebted to you.
I have a 94 Rodeo 4WD with 111k on it. I bought it about 1.5 years ago, and there has always been a not quite right noise coming from presumably the exhaust system- which was made more noticeable as the rpm's rose. Then, all of the sudden, as I accelerated up a hill, the noise turned into kind of a metallic whooshing noise (like restricted air flow through a catalytic converter). A few days later, I came out to my truck to see a small puddle of ATF under it.
So, I pay $1300 to have my tranny rebuilt. The mechanic tells me an overheating problem caused a breakdown inside my tranny, and after I saw the disassembled tranny, I believed him. Prior to any work being done, I told him about the strange whooshing noise, thinking there was a correlation between the two, but he didn't think so.
Fast forward a week and another AAA call later, the truck is back in his shop. This time the tranny light and the ATF Temp light came on. He now tells me the cat is clogged and that's what caused me tranny to overheat. It sounded great the way he described it, but I have no idea what he was talking about. I asked him to just repair the damaged tranny (under warranty), and I'll have the exhaust system and cooling system looked at elsewhere.
Well, that would have been just fine with me, but that was nine weeks ago. All I've gotten for two months is the run-around on why this truck is not back in my possession. If anybody knows if there is a link between a clogged cat and a burned up tranny, please let me know. What I'd really like to know though, is what in the hell can I legally do to get my truck back from this man with a fully functioning transmission?
Thanks in advance for any help!
Old 09-16-2005, 02:05 PM
rodeo02 rodeo02 is offline
A plugged catalytic converter could make your engine run hotter than normal, which will increase the heat load on your trans, as the trans and engine share the same radiator/cooling system for cooling purposes. However I doubt these two are related to your problem. The initial ATF leak was probably nothing more than a leaking accumulator piston cover, very common for the 4L30E. Running low on ATF will cook the 4L30E in a very few miles. Shops are quick to want to do a 'rebuild' for anything. Get the truck to someone you know you can trust.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-16-2005, 10:32 PM
Ramblin Fever Ramblin Fever is offline
Re: cat conv=tranny problems?
Agree 100%, sounds like the shop just wants your $$$.
Don't go to AAMCO either.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-17-2005, 07:41 AM
Thanks for the input, guys.
