Old 09-15-2005, 11:33 PM
vantage1112 vantage1112 is offline
Question 4 wheel drive
4 wheel drive
my 98 blazer pulls hard to the right when I engage the front wheels it also drags down the power when I try to disengage it won't until I hit a bump or stop and start
Old 09-15-2005, 11:39 PM
drdd's Avatar
drdd drdd is offline
Re: 4 wheel drive
what ???!!!???!!!
Originally Posted by vantage1112
4 wheel drive
Old 09-19-2005, 10:23 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 4 wheel drive
What have you checked?
Are the front wheels the same as the back wheels?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-19-2005, 02:26 PM
Cailen Cailen is offline
Re: 4 wheel drive
Sounds like your hubs are partially engaging.
First, and easiest thing to check is the fluid level in your Tcase. Open the upper level check plug and make sure that the fluid level is at the hole, or no more than an inch below it. While you're at it you should probably just change the fluid. Use only Dextron III. Double check but I think it takes about a quart (I say double check because it might be a quart and a half).
Double check that your 4wd fuse is not burnt.
Do a "calibration". Put your vehicle in neutral, and shift from 2hi to 4hi. When the light stops flashing and the 4hi light is solid shift in to park. Repeat process from 4hi to 2hi.
If none of this gets your 4wd working properly you have a few more easy things to check:
Using a test light or voltage tester ensure that your switch is working properly.
Make sure that the vacuum line to your actuator is not leaking.
If everything above is operating properly then your actuator motor is likely burnt. It doesn't sound like that's the case though, so good luck.
Old 09-19-2005, 07:30 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Ever have a problem when you press the 4HI button it flashes and then does not light, but neither does the 2HI? So basically no lights are lit?
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-21-2005, 11:06 AM
So has anyone had the issue mentioned above? Anyone able to give me some advice on this?
K&N Air Filter
Old 09-21-2005, 08:08 PM
BlazerLT's Avatar
AF -Advisor
Re: 4 wheel drive
Please start your own thread, this thread is for the thread starter's concerns.
Old 09-21-2005, 08:14 PM
Re: Re: 4 wheel drive
noted
K&N Air Filter
