It's 1996 3.8L Camaro.
I filled up my car with gas, 14.2 gallons to be exact. I started driving and notice the car was extemely sluggish, IE not accelerating smoothly. I continue to drive and then the check engine light starts flashing, and the car becomes increasingly sluggish. I know I should check the computer code, but it's late and I want to see if you guys can narrow it down. I will run to autozone tomorrow to figure out the problem. The car does have crappy fuel injectors, did they officially crap out on me? Spark plugs? Bad gas? I just hope this problem is cheap to fix, I JUST got enough money to build my computer ($1300) and don't want to have to spend it fixing my car... -Kevin |
Re: Need help with crappy acceleration.
Post the code they give you at AutoZone, I bet it's related to the EGR system.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
Ls7!!!!!!!!!!!!
Formerly Blownalcoholboy 1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi) Best ET 1/4: 8.35 @ 170mph (275 drag radial) Best ET 1/8: 5.44 @ 132mph (275 drag radial) Best 60': 1.31 on the back tires (275 drag radial) AF User Rules/Guidelines http://www.automotiveforums.com/vbul...uidelines.html |
First make sure your gas cap is on tight, that can cause a problem with the evap system and throw a code. Thing is if your SES light was flashing then you had a misfire, so id say do plugs/wires
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
Whats up with the Evap shit-its just a vacuum leak.
Sounds like a plugged cat involving the second O2 sensor. Or maybe some other things such as EGR,MAF,some Crank pos sensor, cam pos sensor, bad fuel pump or any other crapy ass emission thing. Missfiring too but it would be noticeable. |
