Old 09-15-2005, 10:08 PM
faroutguy faroutguy is offline
Easy to do?
I was looking for some cheap easy to do stuff i can do to my cavalier to make it run better, and i am new at working on cars, so far ive changed a horn, done some work with my stereo and changed my air condensor. So im just looking for some easy things i can do to help my car run better and last longer (its a 96 standard cav if that makes a difference) thanks in advance
Old 09-16-2005, 04:14 AM
Coupons420 Coupons420 is offline
i dont know what spark plaugs came witht he 96 but i got a 91 and i changed the plugs for bosch plat 2 and ti ran ALOT better, not faster just better in general.. but i dont know maybe the plugs i had were old and failing. a short throw shifter would be the best for u mostly... there freakin awsome 1/3 the shifts! but aloso like 150$ i'd say cold air intake but thats alot to...the car shoudl alredy run great how it is.. just take care of it and use sythetic oil...
Old 09-16-2005, 07:03 AM
Lvtrucks2000 Lvtrucks2000 is offline
CLean the throttle body with cleaner and a tooth brush. (open the valve) Then keep up with fuel, air, oil Filters. new plugs, wires, PCV Valve, keep all fluids clean and freash.
Old 09-16-2005, 02:15 PM
4dr92cavi4cyl's Avatar
4dr92cavi4cyl 4dr92cavi4cyl is offline
Re: Easy to do?
I see alot of people get in their car, start it, and almost immediatley throw it in reverse or drive and go. Not good. It takes about ten seconds for the oil to circulate and lube all the parts.
Also give it about five or ten seconds to completely idle down before you shut it off, this helps it start smoother.
I've heard many times to only use AC Delco plugs, but I have been using NGK V-power for over a year and they work great. Make sure the engine is completely cool before changing them, if you didn't already know that.
Odometer: 223259 & still running like a horse!
Rockin' to: Dream Theater, Queensryche, Symphony X, and Pagan's Mind. Check them out!
The "radio groups" these days have lost creativity and skill. It's the same thing for five minutes.
Old 09-17-2005, 06:27 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
in regards to the last post, another thing to do is let it idle down before putting it in gear (assuming you have an automatic)
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
