Old 09-15-2005, 08:47 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
removing o2 housing
Can you take off the o2 housing without removing the turbo?
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 09-15-2005, 08:52 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
ya with the right tools. I was able to put in my dump pipe without pulling the turbo. Took about 45 mins cause I didn't want to snap those rusty bolts.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-15-2005, 09:12 PM
Re: removing o2 housing
mine are new ones just put them in i was just needing to do it so i can seal this crack in the by the w/g flapper
MODS
Old 09-15-2005, 11:10 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Re: removing o2 housing
yeah just be prepared to have some wierd ass angles for taking off the o2 housing bolts.
1991 GSX 2.3 Stroker
Old 09-15-2005, 11:38 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Re: Re: removing o2 housing
First time is an experance! I found two extentions, and a swivel joint worked best when cracking the o2 bolt with the coolant line right on top of it!
DSM geek
Old 09-16-2005, 01:17 AM
thanks i will do that tomorrow and maybe i will be able to plug up that crack in the exhaust housing. Hopefully the turbo will spool up faster because right now it takes forever.... 15 at 5000 rpm's.
MODS
