Old 09-15-2005, 08:38 PM
bumpinkicker04 bumpinkicker04 is offline
3 subs
I want to put 3 12" subs in my suv. But i can't figure out for the life of me how to wire them up. Series, parallel, or a mix of both? I have not decided whether to go with dual or single voice coil so any recommendations as far as what subs to use or anything else would be appreciated. thanks in advance for any suggestions.
Old 09-15-2005, 08:47 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: 3 subs
why 3? why 12"?
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 09-15-2005, 10:19 PM
pimprolla112's Avatar
pimprolla112 pimprolla112 is offline
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
Re: 3 subs
Get 2 15's or a big ass 18"
check these sites
www.reaudio.com, www.adireaudio.com, www.ascendantaudio.com, www.soundsplinter.com
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
Old 09-15-2005, 11:59 PM
Re: 3 subs
My first system consisted of a 10 Jl and it did not put out enough bass. So next I went with a 15" kicker SB which out out great bass but it was not responsive enough. I want to go with 4 10" subs but the space I have to work with is a little limited because I would still like to have some storage capabilities in my suv. So i figured 3 12" subs would be the answer. I have seen them in other vehicles but I have never been able to pull them out and see how they were wired. I feel 12" would be the best compromise between bass output and responsiveness.
Old 09-16-2005, 12:47 AM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Re: 3 subs
By responsness I think you mean quickness, and contrary to popular belief the size of the sub has nothing to do with it. So I say go with 2 15's or an 18 or hell even 2 18's.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 09-16-2005, 02:39 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Re: 3 subs
yea, definitely a popular misconception. It may be you had the 15" crossed over too high. A 15" speaker doesn't make a very good midbass driver.
Old 09-16-2005, 02:58 PM
Re: Re: Re: 3 subs
no by responsiveness i mean it takes a 15" longer to reset itself to prepare for the next hit than it does a 12" or 10" sub. I listen to wide range of music from rock to rap, jay-z to twista. On songs that have long deep bass notes a 15 sounds fine but on a song with a littlr bit faster beat like say jay-z's 99 problems the 15" just can't keep up.
Old 09-16-2005, 04:28 PM
Re: 3 subs
No it doesn't. It's the same coil in the same motor. Just a bigger cone.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 09-16-2005, 05:09 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: 3 subs
haha, that was the bigest load of bull ive ever heard...the suspnesion will snap the cone right back to resting position as soon as power is removed...it doesnt "set up" to a beat, it simply takes the given input power fluctuations and turns them into linear movements causing sound... how accuratly it does it has nothing to do with cone size and, is forsure, not going to be behind the beat...
Old 09-16-2005, 08:01 PM
So what you guys are telling me is that you think a 12" sub and a 15" that are basically identical, in the exact same conditions, are going to sound the same with the same music going through them? Yeah I did't think so
Old 09-16-2005, 08:05 PM
Re: 3 subs
Sorry I should rephrase that each one would be as accurate in their production of bass.
Old 09-16-2005, 08:38 PM
Re: 3 subs
either way I am done with the convo about responsiveness. Does anyone know th opotimal way to wire 3 subs? that is the only thing I need to know. I might after a little more thoughts about designing the box go with 4 10" subs but I just wanted to explore options. Thanks in advance for all advice and I appreciate all input thusfar.
Old 09-16-2005, 09:38 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
Re: Re: 3 subs
it depends on if they are dual VC or single VC. and what type of amp you will be using. 3 4 ohm subs run in parallel will be 1.3 ohm load which only some amps can handle. and it they are DVC will be a 2.66 load.
check out this link
http://www.the12volt.com/caraudio/wo...igurations.asp
this website is very helpful and has several calculators to help builb boxes and figure out wiring.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 09-16-2005, 09:44 PM
CBFryman's Avatar
Banned
Re: 3 subs
yes, actually i do. would you like to hear my 18? your gas money to prove yourself wrong...
and the optimal way to wire 3 subs depends on three things.
-Nominal Impeadance of Drivers Coils
-Number Of Coils in Each Driver
-What Minimum Load The Amp Is Stable at
give us thoes and we can tell you... but 2 12's have aproxamitly the same output as a single 15 except for the 15 has twice the motor efficency.
The misconseption that 15's and larger cant produce sound as accuratly as a number of smaller drivers has come about because 15's have always been conceaved as SPL drivers, coils with a lot of windings and layres for more power handleing have high inductance, making the motor incapeable of producing higher ''bass'' frequincies as loudly because of impeadance rise due to inductance.
Also, the greater slightly mms does have an effect on the drivers ability to acurately produce higher frequincies but this point generally doesnt come untill 200Hz or more. far above what a sub SHOULD be asked to produce.
a high cross over point (80-100Hz or higher) with a smaller slope (if you are going to cross over that high 12 db/octave should be theminimum, 18 or 24 would be optimal) can cause sound to become muddy and inacurate an even cause cancelation.
Now the idea that several smaller drivers are more accurate when produceing bass frequincies is not only innacurate, if not correctly wired it can cause MORE distortion. this is due to subs being slightly out of phase causing cancelation which makes everything a muddy ass sounding mess. it also cuts back on posisble loudness... a good example has just come up on SIN. a guy had 32 8's in a hatch, he could only hit 152dB because of cancelation... a single 15 has hit 151 by our very own noah (ngsm13)...and he has it as his daily set up too, i beleive.
now if you still want 3 subs that is fine, 3 12's has more wow factor than a single 15 to your uneducated onlooker...but we are simply trying to dispell common misonceptions and give you best bang for buck.
Old 09-16-2005, 10:22 PM
Audio Guy
actually, I answered this question .... what most people think of as tight bass is caused by the midbass driver. the typical range of a sub 20Hz to like 60-80Hz does not require a driver with lots of speed. Sloppiness in bass can be caused by lots of things ..... "heavy" cones, underpowered amps, poorly tuned boxes, playing them outside their intended freq range ...... too many variables to attribute sloppiness to just the driver.
