Old 09-15-2005, 04:48 PM
chevy70impala chevy70impala is offline
Question Brake light switch replacement
I need to replace the switch but cant seem to get the retainer spring, clip off that holds it to the pedal does anybody know an easy way to get this off. The truck is a 1997 ck2500 if that helps any
thanks
Old 09-16-2005, 12:49 AM
Hope this is helpfull to other readers. I bent the three flat prongs on the clip up as flat as I could then they broke and the ring came right off. It was broken then but found putting zip tie around plunger bar and metal part of brake pedal (metal plate above the actual pedal itself) then run another tie around bar and new switch alot easier than trying to put no clip on. This sounds bad but is fairly easy and there is no extra pressure put on the ties while pedal is being used so they won't ever break. Makes it easier if it ever has to be replaced again.
Just how I did it thought I might help someone else, others may think its rigging but hey it worked good.
Old 09-18-2005, 05:56 AM
Wheeler88's Avatar
Wheeler88 Wheeler88 is offline
Re: Brake light switch replacement
Use an ice pick or a long scribe and insert it where the clip folds over on itself. Then give the ice pick handle a hit with the palm of your hand. Clip pops right off with minimal cussing, unless you can't find where the clip poped off to.
88' Chevy K1500 Silverado
350 V8 5.7
Original Owner
77,000 miles
2nd tranny
Peeling Paint - Defective Factory Paint
235/85/16 BFG MT
