Old 09-15-2005, 02:41 PM
dsmkid95 dsmkid95 is offline
Send a message via AIM to dsmkid95 Send a message via Yahoo to dsmkid95
Boost Leak Need help
Well i had a pretty bad boost leak a couple days ago and did a boost leak test and found that the lower IC hose came off the bottom so had it put back together and it was running perfect. Driving last night i floored it and the same (sound) thing happened again so i took a look at the lower IC pipe and its still clamped on there and im not not making boost now. could this still be ic piping related. it looks like the pipe has swelled up and didnt go back to its normal shape. just trying to figure out if its time for hard pipe? i cant really see if the upper pipe is on there because i cant really access it. anyone help on this part?
Team Addiktion
155 down the 47
Old 09-15-2005, 02:59 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
Re: Boost Leak Need help
You need stronger Clamps and might as well upgrade to pipes.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 09-15-2005, 09:01 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
build a boost leak tester and pump it up, but watch your AFTERMARKET boost gauge. it could be as little as a vacuum line on off that is causing this.And if it is the hose you will hear air coming out of t. if you dnt hear anything, look at you gauge and see if it holding pressure
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-15-2005, 10:16 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Did you do another test? the pipe could be torn. I'd say use t-bolt clamps they work awesome they cost a littlle more but you can even get them at crapa.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-16-2005, 04:25 PM
kjewer1 kjewer1 is offline
AF - Advisor
I have seen stock rubber IC pipes have holes in them that didn't really open up until a certain pressure level. Do a more thorough job with the boost leak tester to rul everything out. You should be able to get it to hold 25 psi dropping to 0 only after a couple minutes.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-16-2005, 10:30 PM
99eclipsegst 99eclipsegst is offline
I don't mean to still your thread but i just have a quick question about the leak tester. where is the best place to find the stem valve?
1999 Eclipse GST
Mod List: T-25, greddy boost controller, k&N intake, Apex'i Exhaust, Boost Gauge, Greddy BOV, Greddy IC Piping, Dump Tube Mod, Symborski Shifter Kit, B&M Short Throw Shifter, Turbo Timer, and Apex'i DP.
Future Mods: Evo III with supporting mods in 2-3 months .
[IMG][/IMG][IMG][img]
Old 09-16-2005, 11:50 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
NAPA ... or "crapa" as some like to refer to it.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 09-18-2005, 12:44 PM
i got mine at discount tire for free....well it was the second clamp on the licp so i swapped it out with t-bolt clamps and now its perfect. thanks guys...oh and i built my boost leak tester and it was great..
Team Addiktion
155 down the 47
