Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-15-2005, 02:24 PM
bellybopper bellybopper is offline
1993 century crankshaft sensor
Having some problems locating it any help? 1993 3.3 v6 century custom
Old 10-29-2005, 04:33 PM
Aceventer Aceventer is offline
Re: 1993 century crankshaft sensor
I have a 92 century and mine is located at facing the car turn your wheel so the left front tire is facing out( like if you were going to make a sharp right turn)look toward the engine and you will see 2 bolts attached to a cover the bolts should mount up like this :take them off and remove the cover the censor is behind the plate.I was told it unplugs and that is how it's replaced.Hope this helps.My car had one replaced before, symptoms were the car would run about 5 min then quit.Then i'd have to let it set for a while and it would restart but if ran too long it would shut down again.Hope this helps.
