Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-15-2005, 12:47 PM
surferfletch surferfletch is offline
recovering starter mounting bolt dowels
I'm replacing the starter. Finally wouldn't kick in this morning at 7 AM. Easy enough to get the old one off. Just 2 mounting bolts and disconnect 2 electrical connections. I'll put the new one on as soon as I can recover the 2 dowels that help align the starter. They are round brass rings which are inserted in both the starter mounting bracket and the tranny housing. I can't puul them out of the old aluminum starter mounting bracket. I tried heat. I tried banging them. Any tricks?
Thanks.
Old 09-15-2005, 02:09 PM
Re: recovering starter mounting bolt dowels
PB Blaster...
Old 09-15-2005, 02:23 PM
Vice grips! Grabbed 'em and spun 'em.
Old 09-20-2005, 10:33 AM
directory's Avatar
directory directory is offline
the vice-grip thing does work, i watched "over the shoulders" as a guy did that.
he squirted a bolt remover something or other also, and let it sit for about 30 minutes. it broke up the grime and rust, he said.
good luck.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 09-20-2005, 10:55 AM
That's how I got them out. These things don't pop into my head as readily as someone who does it every day! The new starter has performed great so far. It's a NAPA reman unit, if you didn't see it in the other post...
