Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-15-2005, 11:26 AM
neon3 neon3 is offline
Remove and replace transmission governor
Where can I find a schematic that shows how to replace the governor in a neon 3 speed automatic?
Currently the car will shudder real bad and just before you come to a full stop the trans will pop into first gear. I have checked the shift cable and it is in good working order. After inspection of the trans, it appears that the governor has chunk broken out of it. I changed the trans fluid & filter right away, and everything else is working just fine. Before I take this thing in to do a full trans re-build, I thought replacing the governor may solve the problem. It looks like you can remove the cover plate on the side of the trans, but do not know how you pull the shaft the governor rides on.
Old 09-15-2005, 02:01 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Remove and replace transmission governor
From my 99 FSM...
"The governor can be replaced by removing the the transaxle oil pan and valve body assembly. The governor can be unbolted from the governor support and removed from the transaxle for reconditioning or replacement.
When cleaning or assembling the governor, be sure the governor valves move freely in the bores of the governor body."
If you give me your email, I can email you the PDF of the neon transmission.
Old 09-15-2005, 06:58 PM
Re: Re: Remove and replace transmission governor
Originally Posted by das2123
From my 99 FSM...
Thanks for your response. If you could send the PDF, send it to:
[email protected]
Your help is really appreciated.
Old 09-16-2005, 07:32 AM
Re: Re: Re: Remove and replace transmission governor
[email protected]
Emailed it to you this morning.
Old 09-16-2005, 05:38 PM
jordan_davis jordan_davis is offline
yeah sure. you want to remove it because its giving the car trouble. Not because you wanna see how fast you can get the f*cker
Old 09-25-2005, 06:27 AM
nimitz23ky nimitz23ky is offline
Send a message via AIM to nimitz23ky Send a message via Yahoo to nimitz23ky
actually, how do you go about getting that thing out of the way...as well, if you do take it out, do you have to put it back in, in order for the car to run? does it really need it?
