Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 09-15-2005, 11:19 AM
drive2quik drive2quik is offline
Tow Package ???
I found out that a 1994 Villager can tow 3500 lbs. with the tow package and a weight distribution hitch.
How can you tell if you have the Tow Package with the 3.27:1 axle ratio?
How is a weight distribution hitch different from a standard hitch?
Any help would be greatly appreciated.
Thanks,
Chris
Old 10-19-2005, 12:45 PM
Hollowcreek Hollowcreek is offline
I'm towing a little over 2000 lbs with my '02 which as far as I know does not have a tow package ( I have a Sport, I think the Estate had the tow pkg.) . A weight distribution hitch basically means it attaches to the frame. Gas mileage is poor (goes from 25 hwy to about 15) and stopping is dicy so don't tailgate.
Old 10-23-2005, 06:37 PM
IH8SPM's Avatar
IH8SPM IH8SPM is offline
Re: Tow Package ???
IF you have the tow package you will have the cables for the tow hitch installed.
Old 10-24-2005, 04:01 PM
Did the tow pkg consist of more than trailer wires?
Old 10-24-2005, 08:19 PM
redvillager33 redvillager33 is offline
Re: Tow Package ???
The factory tow package consisted of full size spare tire, wiring harness with a 4 pin connector, and additional transmission oil cooler. To get to 3500 pound towing capacity - you needed the additional transmission oil cooler. The wiring harness is up underneath the rear bumper and is a 6 pin female connector with a 2 foot adapter that has a 6 pin male on one end and a 4 pin on the other end.
You had to add the weight distribution hitch, which bolted up to pre-drilled and tapped holes in the frame.
Hope this helps.
