Go Back   Automotive Forums Car Chat > Honda > Integra
Old 09-15-2005, 07:11 AM
pacman99 pacman99 is offline
Is this normal?
Hi,
This may seem like a dumb question but i've been driving a crappy sunfire all this time so I don't really know much about handling and what not. I just recently bought my integra and was wondering if this behaviour was normal:
On certain roads, the steering wheel, when let go, automatically begins to turn to the right and the car begins to drift to the right (or left, depending on the road). On some roads, I have to firmly grip the steering wheel so it doesn't start turning on me. I've driven my sunfire on the same roads and haven't had this problem.
Just wondering if this is normal on integras and I just have to get used to it or I got screwed over by a dealer again lol.
Thanks~
Old 09-15-2005, 02:21 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Is this normal?
alignment would be my first shot.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-15-2005, 02:33 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Is this normal?
I have a similar problem with my civic, my friends say it's some bushing that is beat (couldn't hear what one because there was a loud engine reving when they were telling me). I noticed it this past winter and once I put on my summer rims (much wider), there was no understeer like there was last summer. I also have no power steering, but it almost feels the same as my rent's cars that do have it. So check the alignment and then check for any damaged bushings, if the alignment is ok.
Old 09-15-2005, 04:05 PM
Re: Is this normal?
if the alignment was off though, wouldn't the car sort of vibrant when i brake on the highway (when i'm at high speeds?) Because it doesn't in my case. But i guess i can have that checked out, not that expensive.
So it's not normal eh. Good :P
Old 09-15-2005, 06:16 PM
spaminator's Avatar
spaminator spaminator is offline
Send a message via AIM to spaminator
Re: Is this normal?
a car that needs alignment doesn't shake it just drifts
You're think of a tire out of balance.
It's possible that the bushings need to be replaced. Order a set of Energy Suspension polyurethane bushings if you choose to go that route
Horsepower is how fast you go into the wall. Torque is how much of the wall you take with you.
Originally Posted by YogsVR4
Everyone gets only one birthday anyway. We come out and about half of us spend a good portion of the rest of our lives trying to get back in.
Old 09-15-2005, 06:23 PM
Re: Is this normal?
i had it looked at by my mechanic. He said the wheel bearings at the back are bad or something...something along those lines hehe..anyways since i just bought this car, he said to try getting the dealer to fix it for free and then if not, then i guess i'll have to spend some money
bushings = wheel bearings?
Old 09-23-2005, 06:01 PM
grimmis grimmis is offline
Send a message via MSN to grimmis
thats not normal. my teg did it when i first got it and it as just the alignment but if you get the alignment redone and it starts to do it again its a suspension problem
Old 09-23-2005, 08:14 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
Re: Is this normal?
bushings are not wheel bearings....... wheel bearings are what holds your axle inside the hub and keep it spinning freely.... bushings are suppost to put a little cushion between the places where something needs bolted (on suspension)
-IB-BI-... I=a bracket B=bushing -=bolt
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 09-24-2005, 01:32 AM
x1o4gboi x1o4gboi is offline
is the car eating up your tires? my brothers car does is sorta like that too. In the rain it slides even more and check your camber kit.
Old 09-24-2005, 04:32 PM
Re: Is this normal?
tires seem fine but it's weird. 2 weeks ago I put air in all four tires, 32psi for front, 30psi in the rear. Today I check back and has like 5psi, Front are fine. So that could have been it. I'll drive it a bit more and see if that fixes anything.
Old 09-26-2005, 02:05 AM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
Re: Is this normal?
check your tie rod ends. or just replace them. theyre not that expensive and they cause that sort of thing. that is if your car is still doing that after you put air in your tires.
Old 09-26-2005, 12:32 PM
Re: Is this normal?
although it's doing it less, it's still doing it but on SOME roads not all. I think it's just that I have to get used to a car with so much handling because if this problem really was with the car, then I think it should happen on all roads, including the highway where the road is perfectly straight and levelled :P
What do you guys think?
Old 09-27-2005, 01:25 PM
Chad51 Chad51 is offline
My '92 Integra has a similar problem. It used to be really bad but I had new tires put on and the problem was pretty well gone but I am starting to notice it a little bit again even though the tires all seem fine. Might take it for an alignment though and see what the results are.
Old 09-27-2005, 06:23 PM
tycburgess tycburgess is offline
Send a message via MSN to tycburgess
Re: Is this normal?
One more thing. I don't know how much drift your getting, but i've noticed in uni-body vehicles a tendency to drift a bit with the leaning of the road, as it were. 'course you'd probly notice that with your sunfire, but just a thought
Old 09-27-2005, 08:05 PM
Re: Is this normal?
yea that's why I was a bit worried. I took my sunfire on the same route for about a year, when it was raining, snowing like crazy, really icy, and perfect road conditions. I barely felt any drifting, even during icy conditions. But as soon as I got my integra, it began to drift on certain roads but runs fine on others.
You're right, maybe I should just get an alignment and see if that fixes it. The tires don't seem that great either so that might be the problem. If i kept driving like this, other than annoying me, woudl there be any other serious consequences? I'm sort of broke right now I'm going to do the timing belt on this soon so..
