Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-15-2005, 05:23 AM
ukozzy ukozzy is offline
Send a message via AIM to ukozzy
lincoln hesitation
I have a 1986 town car, 69,000 miles on it. problem I am having is when I am in overdrive and not pushing the engine, every now and then seem to get a hesitation. If I push it, doesn't happen. Seems like the engine slows for a half second and can happen multable times, hard to tell if its the engine or maybe its dropped to 3rd and kicked back up to overdrive. Its driving me crazy. Your help would be appreciated if anyone has experienced this before.
Old 10-06-2005, 02:22 PM
Hizhonor's Avatar
Hizhonor Hizhonor is offline
Send a message via AIM to Hizhonor Send a message via MSN to Hizhonor
Let's try mechanical first: Check the TV Bushing on the throttle body to make sure it's not worn and the TV cable isn't loose. Next, make sure your fluid level is correct and that the fluid is clean. If not, flush it and the torque convertor and then refill plus add a bottle of Lub-Gard RED Label. If there are signs of engine hesitation, I'd say plugs, wires, fuel filter MAP sensor or clogged EGR channels. Good luck and let us know how you made out!
VP & Co-Founder NELCE
Northeast Lincoln & Cadillac Enthusiasts
http://www.nelce.org
The BEAST in all it's glory!
Old 10-17-2005, 04:34 PM
edflores edflores is offline
Re: lincoln hesitation
Hey, man i have a 93 town car with 130,000 on it, and its doing the same thing. did you ever figuire what was wrong with it. write me back
Old 10-17-2005, 10:25 PM
Towncar's Avatar
Towncar Towncar is offline
I don't know about the rest of you die-hards here, but for me, it burns my ass when the OP never comes back with a response.
Did hizhonor's advice have any effect on the problem?
Maybe we we're looking for a cheaper solution, and still looking?
-Steven
1996 Town Car, Cartier
Old 10-18-2005, 04:05 PM
Hizhonor's Avatar
Re: Re: lincoln hesitation
Well, for anyone who needs it, here's the Motorcraft number for the TV Bushing. It's brass and won't wear away like the plastic one that's causing all the problems out there. F3SZ-7H303-B Transmission Throttle Valve bushing
As far as YOUR 93 ... try cleaning ( just spraying with electrical contact cleaner and letting dry thoroughly) your MAF sensor. It's right behind the air filter box on top of the silver tube. You'll need a #10 Security Torx Bit to get the screws out. If that doesn't solve the problem then you need to have the EGR channels cleaned. At 130K, if it's never been done, that could be the culprit.
Good luck
