Old 09-15-2005, 01:47 AM
joniboy joniboy is offline
how to build a LS VTEC
i've been searching an how to build an Ls Vtec And all i find is some Ideas, I need the step by step instruction and photos an how to built it
anyone? help
Old 09-15-2005, 03:00 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: how to build a LS VTEC
whatcha gotta do is take ya one of them non vetec b motors, one of them withouts the vetec. Then you takes you a vetec head and yous throws it on the non vetecs motor. makes sure yous takes out that there oil squirter thingy before you bolts down that vetec head of yours. Now alls you gotta do is wire that vetec up and you'll be haulin ass like a summbitch.
Old 09-15-2005, 10:29 AM
b1886crx b1886crx is offline
you have to use a b18a,b18b(ls integra bottom end), Any b-series head(b16a,b18c)along with everything on the head,cams, sprockts, intake manifold,throttlebody,etc. Use the ls timing belt, you have to plug the original oil feed line on the head or it will leak oil , use the metal vtec head gasket. you have to run a new vtec oil line from the back of the ls block to the head, and wire uup the vtec solenoid. you can use any b-series tranny, b16,b18a,b18c. the b16,b18c is better than the ls.your can also use the pistons,oil pump on the ls blockthus making a 1.8L b16a, the ls pistons compression ratio is a lot lower than a stock b16 or stock b18c.
Old 09-15-2005, 11:28 AM
88ReX 88ReX is offline
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
Old 09-15-2005, 04:13 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
m4d vtak y0 !1!!11!
Team Lonely Drivers
Old 09-17-2005, 11:57 AM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
anyone? help
go to www.B20VTEC.com
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
