leganza seems to guzzle to much gas
hello, I have a 1999 leganza. i recently purchased it from a private seller. i fill up the tank full of gas, and i can only go about 275 miles on that tank. is that normal? or is something wrong? suggestions?
Also, when i am driving on the freeway, and i let off the gas, it seems to slow down to fast. ( this is just when i coast). I am not sure what it is. and i am pretty sure that the brakes are not rubbing. any suggestions there? thanks for any help. |
I get 480 to a tank, get a tune up, oil change and make sure you get the timing belt done.
Re: leganza seems to guzzle to much gas
What do you mean by the timing belt? could you be a lil more specific? thanks |
Re: Re: leganza seems to guzzle to much gas
How Can I tell if the overdirve is on? Its actually a friends car. so I cant go look at it? thanks.
In all automatic leganzas, when overdrive is on there is a orange indicator on your console that lights up "pwr". The pwr/overdrive button is on the left side of the of the shifter below the gear button. You should also have a "hold" button which allows you to go through the gears like you can with a subtronic shifter found on many of the newer luxary cars. (Though the leganza is a far cry from luxary)
