Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-14-2005, 11:09 PM
GHD1959 GHD1959 is offline
Timing Belt on Rodeo
I have a 97 Rodeo manual with the 4 Cylinder, and have the original timing belt along with original brakes and clutch. The truck has 150,000 miles and runs great and the water pump was changed at around 100,000 miles and the timing belt was said to have been fine. I realize I am way overdue according to the manual, but should it be changed since is sounds and drives fine? I have read other posts on this all over the boards.
Old 09-14-2005, 11:14 PM
Cat Fuzz Cat Fuzz is offline
Time to change it. You can't always tell by a visual inspection if a t-belt is going bad. Better to do it now then have to get towed home.
Old 09-15-2005, 12:10 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Timing Belt on Rodeo
way over due.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-15-2005, 02:55 PM
rodeo02 rodeo02 is offline
You will smash the intake valves if the timing belt breaks on the fly on this engine (interferance engine). It's cheaper to replace the t-belt, associated hardware and make sure the waterpump is good to go!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-18-2005, 09:38 PM
Timing Belt
I had it changed.thanks
Old 09-19-2005, 12:26 AM
Ramblin Fever Ramblin Fever is offline
GHD1959 - Have to ask, how's that thing on the highway?
I mean a 5K# truck with a 4-cylinder?
I personally couldn't see how a 4-cylinder could pull my 97 Rodeo, with all of it's accessories, but you seem to be doing good and you still enjoy it.
That little 4-cylinder must have more pep then I thought.
How's it loaded down?
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 09-20-2005, 04:08 PM
rvaccare rvaccare is offline
G/luck
Joel
I thought the Rodeo is a non-interference engine?! I don't know myself, but I could swear I have read that a few times on these forums. I am at 110,000+ and need to change my timing belt, so I sure hope it is a non-interference engine, or else I better get moving. You see, I have this problem with procrastination when it comes to my vehicles.
Old 09-20-2005, 04:29 PM
Re: Re: Timing Belt on Rodeo
Originally Posted by rvaccare
I thought the Rodeo is a non-interference engine?!.........
Any of the 4cyl rodeos are interference.
G/luck
Joel
Old 09-20-2005, 04:32 PM
They are absolutely horrible if you are used to driving 6cyl or V8 trucks. MPG is not great for the 4cyls either. They are cheaper on inital purchase and tend to be cheaper to maintain, those are the plusses.
G/luck
Joel
