Block Heater
Just had the Blazer in for a oil change & I was informed that my block heater is not working. They said they had tested it and that they would look at it next time around, closer to the Canadian winter. He said it may be the cord..or the heater itself.
Is this somthing simple to fix if all it takes is replacing the cord..or the heater unit itself? This is in a 99 LS 4x4 |
Re: Block Heater
and why did he test you block heater when he was changin your oil?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Block Heater
I agree...
1998 BLAZER LS Vin-W 4Dr 2wd 2004 Cavalier LS 4Dr 2.2 Ecotec "Good Part's ain't Cheap--Cheap Parts ain't Good" |
Re: Block Heater
Yeah, I agree BlazerLT, I would inspect the block heater cord carefully for new cuts ASAP.
Do I smell a scam!?
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
Re: Block Heater
I debated whether or not to reply to this post since we don't need block heaters in Arizona. I wouldn't know what a block heater looked like if it bit me in the Arse. It could easily be a scam as there are many unscrupulous mechanics and garages out there, But ya know, maybe the guy found a decent garage that tries to help their customers and is simply trying to give a little customer service.
How many times have you gone into a garage for say an oil change and they come back with a list of things that they recommend to be looked at or replaced? My experience is that it happens at almost EVERY garage, EVERY time. Before we start looking for crooks behind every torque wrench, I'd be leary yes, but give the guy the benefit of the doubt. |
Re: Block Heater
Sounds like a mechanic is trying to make more money.
Re: Block Heater
BLT, Absaluckinflutely
Re: Block Heater
How hard is it to replace a Blazer Block Heater.. mine is shorting out the fuse box in the house when I plug it in.
Where should I check for a short? How? Is it easy to replace? I live in Canada eh! and I need it! Help! Thanks, XPC... ps, this is the only thread I found that had anythign on block heaters... |
Re: Block Heater
95 Blazer LS 4door 4x4.
What else do you need to know? Thanks again.. |
