Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-14-2005, 10:43 PM
kokanee27's Avatar
kokanee27 kokanee27 is offline
Question brake lamp light wont go out
i have a 92 prelude si,, and for the past week my "brake Lamp' light has been on, but ive checked all my brake lights and so has my friend and all 3 lgiths go on and off fine when i brake. the owners manual says its only suppose to come on if a brake light is out, but could there be another reason its on?? if not how to i get it to go out?? and help is appreaciated
Old 09-15-2005, 05:46 AM
chucksnee chucksnee is offline
Crawl underneath your dash and follow your brake pedal up, you will find a switch adjust that switch so the switch fully closes when your take your foot off the brake pedal and your problem will be gone.
Old 09-18-2005, 12:44 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
If that didn't fix it...are you talking about the actual rear lights or the one on the dash? The dash is mainly caused by low brake fluid. Just a suggestion.
Old 09-18-2005, 12:55 PM
kokanee27's Avatar
Re: brake lamp light wont go out
no its the dash light that says 'brake lamp' and the owners manual says it only come on when the brake lights are out, but im takin it in to the shop next weekend, ill get it checked out then.
Old 09-18-2005, 09:24 PM
Unconnected Unconnected is offline
I have a light bulb that loses its connection every so often, resulting in my Brake Lamp light to come on too (89 prelude) but it only goes out for maybe a split second or whatever, but the brake lamp light stays on even when its back on, turning the car off and on fixes it usually.
I doubt this will help, but maybe you have a slightly loose connection to one of ur bulbs, so that when you turn your car on, it thinks a bulbs out, even if it comes back on
Old 09-20-2005, 06:23 AM
With what your describing , and call me nuts but dose'nt that mean that your brake pads are worn out......
