Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-14-2005, 10:28 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
TPS adjustment
Alright i did the throttle body shaft seal replacement yesturday and now my idle surges i figure it's probably the tps there is a write-up on vfaq but i have a 90 with the different tb (two vac line on top two on side) Anyone know how to adjust the tps for this tps?
Thanks
EZ
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-15-2005, 10:13 PM
ez1286's Avatar
Re: TPS adjustment
Ok nevermind i just got into an accident and i think the car is totalled
