Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-11-2002, 06:50 PM
hatchman hatchman is offline
can a type r handle a turbo?
can a type r handle a turbo? and is it even worth it to turbo this engine if you have to do alot of changes with compression. and if not...is there anything that can be done to get more hp out of a type r? ? oh....and no type r hating...lol...its too late, the motor is on its way!!!
Old 05-11-2002, 10:39 PM
boosted331 boosted331 is offline
10.5:1 or whatever the hell their compression is isn't exactly ideal for boost. Get some dished pistons and drop it down to ATLEAST 9:1 and you could run 10-12 pounds safely.
Old 05-13-2002, 02:30 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
IF you have a Type-R motor why not make it all motor? It would do much better as all motor then it would as turbo'ed. Go all motor you will not be disappointed.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-13-2002, 09:00 PM
FBP Si 2000 FBP Si 2000 is offline
Send a message via AIM to FBP Si 2000
Yes...
http://www.itrca.com/registry/index....mber=76&car=63
There are a few turbo'd Type-R's on Honda-Tech...they are making some nice power. HTH
'00 FBP Si
Old 05-14-2002, 12:16 AM
RedRocketGSR's Avatar
RedRocketGSR RedRocketGSR is offline
Send a message via AIM to RedRocketGSR
yea i would go all motor on the type R as opposed to turbo. The compression is high but not too high. Either way it wouldnt be bad.
95 Integra GS-R
[email protected]
Old 05-14-2002, 09:53 AM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
ah what the hell..get a small turbo. t25 with a small intercooler. why not?! doesnt matter what you go with all motor, you still cant beat the gains of a turbo.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 05-26-2002, 11:20 PM
3SGTE 3SGTE is offline
IMO, the type R was built as a handler, and mods should not be made to deviate from this. If you want to go fast in a straight line, then get the turbo-- my friend has a R turbo running 12's on stock internals. I don't hear about any FWD cars running boost on autoX tracks. Again, it is your choice, but if you wanted to go fast in a straight line you should have saved the $$ and got a hatch. The R is in a handling class in all its own, and IMO it shouldn't be modded to deviate from that purpose.
Good Luck
Maurice
OOPS... and I said all this before throughly readiing your post.
Friend-R-Turbo-Stock Internals-12 sec slips
Old 05-28-2002, 01:15 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Yes and if its tuned right then u can hit 12's - 13's stock bottom end!
P.S.
Lower compression is not necessary for boost all the time!
Old 05-30-2002, 06:53 PM
ViGGa2LO ViGGa2LO is offline
Send a message via AIM to ViGGa2LO
turbo????
I would most def not put turbo in there... I would like to see a nice crower stroker kit in there... then it would move
Old 06-02-2002, 08:59 PM
Originally posted by mellowboy
P.S.
Not necisary, but I wouldn't feel comfortable driving around a boosted, high compression motor on pump gas.
Old 06-02-2002, 10:01 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
it's been done many time with the Type R. invest in a standalone engine management system and you should be fine with some tuning. without some kind of management system, say goodbye to the precious B18C5
Old 06-05-2002, 09:13 PM
tenzoracerevovii tenzoracerevovii is offline
i think the jdm b18c-r has like....11:1 compression......if i had a type-r motor..i'd probably go all motor too.....just because you get more respect out there....but it's gonna cost a lot more....
but don't think the b18c5 is a bad car for turbo......you know the dc sports 9 sec hatchback rite?....the red one?....it's powered by a b18c5 w/ a turbo.....
of course.....it's all up to you.....but i just wanna give some advice....figure out which route you wanna go BEFORE you start your build-up....just cuz it's like 2 very different routes to go N/A and turbo.....
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Old 06-15-2002, 10:09 AM
92'Sleeper 92'Sleeper is offline
As everyone says with the right tunning you can be ok but I dont think you can boos too high. As far as the hatch with the b18c5 that is running 9's I am pretty sure that, that particular motor is fully built and the compression had to be loweredl....I could be wrong though. In other words you can boost as much as you want but you will have to redo the internals (lower compression, rod) but then what would be the point of buying a Type R motor.
"It LOOKED like a stock hatchback?"
Old 06-15-2002, 11:11 AM
yea.....you're rite....the pistons and shit are probably low comp. so it's not really a type-r motor as much anymore......you can probably get similar results w/ a b18c1.....it's just that the head on the type-r is better than the gs-r......more flow
-me
-obiewancoyote
Old 06-15-2002, 04:30 PM
GSteg's Avatar
lowering the compression isn't necessary. with the aid of some type of standalone engine management system, you're able to boost higher. there are many B18C5 engines running 15psi daily. there is even an LS engine running 20psi on STOCK INTERNALS with the only modification to the block is a blockguard. tuning is everything. lowering the compression is to prevent detonation under SOME circumstances. running ~13psi should be fine with 93 octane gasoline and some tunings.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
