Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 09-14-2005, 10:02 PM
92ExploderJoe 92ExploderJoe is offline
Send a message via AIM to 92ExploderJoe
Question 93 Passat Ignition Wiring..*HELP*
Hello
My friend owns a 92 GTi and he blew his motor and he just got his hands on a 93 Passat GLS 2.8L VR6 great looking car but we aren't sure if it runs there is no key because it's was abandonded over a year ago.
We basically need to Hot Wire the car to make sure the transmission is good or the engine before we do the engine swap in a few days.
If anyone can help me it would greatly be appreciated!
Thank you!
Joey
Firefighter
Medical Response Technician
USAF Auxilary
Old 09-16-2005, 09:58 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
if you can turn the engine by hand at the crank bolt then the engine should be ok. if its been sitting for 1yr than its going to take problably 20-30min of idling to get rid of the cam chain noise. I would reccomend removing the valve cover and applying assembly lube to the chain and cams so there isnt a dry startup.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
