Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 09-14-2005, 07:16 PM
bratt bratt is offline
I cant shift out of Park
i just rebuilt my transmission
i can start the car up but i can not shift out of P
the tranny is bolted on correctly ive quadruple checked it
but i dont know why i cant shift out of park into Nuetral or Drive
Old 09-14-2005, 07:18 PM
Re: I cant shift out of Park
oh yea its a 94 dodge ram 3500 van
Old 09-15-2005, 06:32 PM
restrorob's Avatar
restrorob restrorob is offline
I would remove the shift linkage off the trans. and try to shift right on the trans.,If you still can't shift you will need to drop the pan and find out what you didn't do right. If it does shift at the trans. you have a problem in the column.
Old 09-15-2005, 06:42 PM
OK i did that it moves but it is very very very hard to move. all i changed in the tranny was the friction plates and nothing else
the black mount on the rear of the tranny has 1 side of bolts locked in i did not lock in the other side yet but i dont see how that will affect the shifting
before i stuck the tranny on the car it was easier to shift. am i suppoosed to leave it in nuetral when i put the tranny on the engine?
Old 09-15-2005, 09:44 PM
restrorob's Avatar
Re: Re: I cant shift out of Park
No its not necessary to leave the trans. in neutral, The shift arm only moves the piston plungers in the valve body to redirect the fluid flow for different gears. Sorry I'm not a auto trans. ace but if it shifted fine before you put it back in and now it doesn't something had to happen inside. Did you have the valve body out ? If not and I had this problem I would drop the pan and check the shift detent for any problems, With the pan off you can look in there and move the shift arm and see whats going on.
Again sorry I'm not more help.
Btw; I have seen the torque converter not properly meshed into the front pump and cause a lock-down situation when the bell housing bolts were tightened, But I don't believe it affected the shifting part of the trans.
Old 09-15-2005, 09:53 PM
i will drain it 2morrow and see if i can take the pan off and inspect it for problems
thanks
Old 11-18-2005, 11:28 AM
brattzzzzz brattzzzzz is offline
my buddy turned the driveshaft and i put the valve body off and put it back in and while turning the driveshaft it locks into place as it should
so basically the valve body was not put back in properly. the line was not all the way in but now it is. while turning the driveshaft it gets in there
now it shifts fine
