Old 09-14-2005, 05:21 PM
patoffspyder patoffspyder is offline
I need help to find this color
Hi guys,
I want to build a yellow RX-8, but I want to know if someone know where I can get this color. The color is Lighting Yellow. I have access to Tamiya and Duplicolor paint.
If I can't get it, I will paint it Velocity Red Mica, but I don't think I can find this color in Duplicolor paint.
Hope someone can help me.
Thanks
Old 09-14-2005, 05:30 PM
chenc544's Avatar
chenc544 chenc544 is offline
Re: I need help to find this color
Just do some mixing. Get some Tamiya Yellow and mix it with Gloss White should do it. When I have to mix colors I usually make a big batch so that way I wouldn't have to worry about running out and trying to match the color again.
Old 09-14-2005, 06:17 PM
Yeah but I don't have an airbrush, so mixing is impossible for me :-(
Old 09-15-2005, 10:29 AM
chenc544's Avatar
Bummer. Well if you want to give it a try you could layer the paint. Since yellow and white are both translucent color you could layer them and get almost a mixing effect. What I would do is to put down a layer of white primer and then couple good layers of gloss white and finally thin misty layers of yellow until you get the shade that you want. It would be eaiser just to paint it red but if you want the yellow bad enough you could give that method a try.
Old 09-15-2005, 10:50 AM
blubaja's Avatar
blubaja blubaja is offline
Hey man,
I was at LHS today. I think you cna use testor's Chrysler Yellow, or Tamiya's Chrome Yellow. They look pretty close to me. Good luck.
Old 09-15-2005, 12:33 PM
redstang423's Avatar
redstang423 redstang423 is offline
Unfortunately its tough to do color matches like that when you are limited to spray cans. Like Blubaja mentioned, you could try those colors. Testors has started a line of exact car colors, but I think for the time being, they are mostly classic colors with a few newer ones spattered in there. You might be able to at least find a close color match in that line. Otherwise, maybe you want to invest in an airbrush and get a little practice in before you tackle this project...
Old 09-15-2005, 05:35 PM
Vric's Avatar
Vric Vric is offline
If you want pearl color, Yellow + light coat of White Pearl
Old 09-15-2005, 06:53 PM
Thanks a lot guys, gonna check this out!
Where can I find this white pearl paint? Does Tamiya do it?
Old 09-16-2005, 12:45 AM
proosen's Avatar
proosen proosen is offline
Tamiya also have clear with pearl in it. goes on like a dream on any TS/AS-base coat. I've tried it on TS-54 blue for instance.
Niclas
Hard to see the pearl effect, but it sparkles a bit.
