Old 09-14-2005, 04:05 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Spec Stage 5 Clutch -- Driveable?
I have the non turbo '98 eclipse (420A) with an HRC 20G kit that I'm installing in a week or two. I want a clutch that can support a lot of hp incase i get internals soon. This is a daily driver though. Would a SPEC Stage5 work or is that going to engage way too hard? What is the best clutch for the 500hp range (only at high boost)? Thanks!
Old 09-14-2005, 07:02 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Spec Stage 5 Clutch -- Driveable?
i would get a more streetable clutch for now. to do internals you need to pull the motor and then at that point you can put in a heavy duty clutch
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
