Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-14-2005, 03:25 PM
flansp flansp is offline
2005 Taco Questions
Hello All,
Question, how many grease fittings are there on the 2005 Taco, 6 speed, 4WD, 6cyc.? I don't remeber the exact engine number but I believe it starts with the 1REXXX. Last night I counted and greased 5. Is this it? If there are more could you please indicate where they are? The fittings consisted of three for the driveshafts for the drive train and 2 for the shaft for the four wheel drive.
Paul
Old 09-14-2005, 10:21 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2005 Taco Questions
This is probably similar to yours:
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-19-2005, 02:53 PM
Thanks Brian.
Got another one. As far as I can remember, all of my standard transmissions had a clutch fluid Reservoir (SP?). I was unable to locate one on my truck. Description of truck above in thread. Any idea where this is? Manual makes not mention of this.
Thanks,
Paul
Old 09-19-2005, 05:16 PM
Brian R.'s Avatar
Resident Chemist
Sorry, can't help you on that one.
Old 09-26-2005, 01:31 PM
sunruner's Avatar
sunruner sunruner is offline
Send a message via AIM to sunruner Send a message via Yahoo to sunruner
Originally Posted by flansp
Thanks Brian.
Thanks,
Paul
the 05 tacoma shares the clutch reservoir with the brake reservoir. you will notice a line going from the brake master down to the clutch pedal, thru the firewall. this was a common practice on early saabs as well. as far as the clutch master cyl location, i beleive its behind the clutch pedal now as i see a brake line going to that area. there are other hidden mechanics on this new truck. the wiper motor is located under the cowl, i beleive. the throttle cable is replaced by fly by wire technology.
Old 09-26-2005, 03:13 PM
Flash75 Flash75 is offline
AF - Advisor
"the 05 tacoma shares the clutch reservoir with the brake reservoir." So, if you get a leak in the clutch hydraulics you can perhaps lose your brakes unless there is a partition in the reservoir. In addition to leaking on your shoes, I'm sure the cylinder would be a bear to change.
Clifton
