Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 09-14-2005, 11:36 AM
SupraNatural SupraNatural is offline
Inside Diameter of intake tube.
Can someone tell me the inside diameter of the rubber intake tube between the air filter box and the throttle body? I need to know the size where it attaches to the air box or MAF sensor.
Thanks so much.
Old 10-01-2005, 06:03 PM
ctesla's Avatar
ctesla ctesla is offline
you're not buying one of those Tornado's or Vortex thingies for slipping in the air inlet hose are you?
DON'T!
save your money for three tanks of gas.
if you still want to know,
go to autozone.com or tornado's website, as they list part numbers AND the diameter (in mm) for the inlet tube.
another way to find out, is pull the MAF and measure diameter.
(also, it is difficult to say the exact measurement, as you did not list year; 4.5L, 4.9L, NorthStar, etc. as these do have different intake housings)
hope this helps,
chris
nrt racing
Old 10-01-2005, 06:07 PM
ctesla's Avatar
if you want better gas mileage,
top of the tank with low grade, or premium, and add about 3-4 ounces of Acetone to the fuel, and run it through, then top off again, and re-check your mileage figures.
should be up (depending on mileage and service, and driving habits) at least 10%+, maybe 15-20!
Old 10-11-2005, 09:19 PM
MarkC MarkC is offline
Re: Inside Diameter of intake tube.
what does the acetone do to improve mileage?
Mark
