96 Deville keyless entry, key fob programming
Does anyone know the program procedure for key fobs in a 1996 Sedan Deville? Are they able to be programmed without an expensive visit to the Caddy dealer?? Thanks for your help.
Re: 96 Deville keyless entry, key fob programming
Yes, its a long procedure, but here ya go:
ANALOG INSTRUMENT CLUSTER: With the ignition in the "RUN" position (engine does not necessarily need to be running, but it will work either way). Press OFF and WARMER (or the OFF and PASSENGER WARMER buttons) on climate control panel simultaneously. Instrument Panel Cluster (IPC) will light all telltales, then go blank. System is now in DIAGNOSTIC MODE. After diagnostic mode cycles through and stops, press FAN DOWN button until "RFA?" is displayed, then press FAN UP. If "RFA DATA?" is displayed, press FAN DOWN. If "RFA OVERRIDE?" is displayed press FAN UP button. If "RFA S00 NO OVERRIDE" is displayed, press FAN DOWN. If "RFA S01 PROGRAM FOB #1" is displayed, press FAN UP button. IPC will show "0" on right side of Drivers Information Center (DIC) display. Press WARMER button on the climate control unit until "99" is displayed. Press and hold TRUNK button on the transmitter. While holding TRUNK button, press LOCK button and hold both buttons for a total of 3 seconds. Locks will cycle when programming is complete. If transmitter is not programmed within 30 seconds after entering "99" on the display, system will default and you must begin at step #2 again. To program second transmitter, press FAN DOWN button until "RF S02 PROGRAM FOB #2" is displayed, then press FAN UP. Repeat step #4. To exit system, press AUTO, MODE UP, MODE DOWN, or RESET button. DIGITAL INSTRUMENT CLUSTER igital Instrument Cluster With the ignition in the "RUN" position (engine does not necessarily need to be running, but it will work either way). Press OFF and WARMER (or the OFF and PASSENGER WARMER buttons) on climate control panel simultaneously. Instrument Panel Cluster (IPC) will light all telltales, then go blank. System is now in DIAGNOSTIC MODE. Press FAN DOWN button until "RFA?" is displayed, then press FAN UP. Press FAN DOWN button until "RFA OVERRIDE?" is displayed, then press FAN UP button. When "NO OVRD RF S00" is displayed, press FAN UP button. When "PGM FOB1 S01" is displayed, press WARMER button and "99" will be displayed in the left upper corner of the IPC, just below odometer. System is now ready to program transmitter. Press and hold TRUNK button on the transmitter. While holding TRUNK button, press LOCK button and hold for one second. Hold both buttons for a total of 3 seconds. Locks will cycle when programming is complete. If transmitter is not programmed within 30 seconds after entering "99" on the display, system will default and you must begin at step #2 again. To program second transmitter, press FAN UP button until "PGM FOB2 S02" is displayed, then repeat steps #2 and #3. To exit system, press RECIRC, or RESET button.
Replacement keyless entry remotes available here - up to 90% off - All makes/models from Acura-Volvo, 1988-present - http://www.OriginalKeyless.com |
