Old 09-14-2005, 10:21 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Exhaust system compatibility
I have a question about an exhaust system I am looking at picking up.
I am considering upgrading my cat-back, finally. Anyway, I have a 2.5" DP and 2.5" high flow cat.
Is it possible to bolt up a 3" catback or is there some modification involved? Such as this one:
http://cgi.ebay.com/ebaymotors/Tsudo...spagenameZWDVW
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-14-2005, 11:30 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Exhaust system compatibility
Almost every exhaust system uses diffrent flanges. Worst case senario it will cost you $50-75 for a muffler shop to cut & weld a 3in-2.5 reducer and 2 matching flanges, and install the system.
DSM geek
Old 09-14-2005, 05:28 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I have the tsudo apexi n1 clone. And I have a meagan 3 in downpipe and mine bolted up just fine. I didn't have to make any modifications and I was able to use the same exhaust hangers as well. The worst case senario is that you might have to replace one of those hangers. But other than that you should be good.
Only way to find out is buy and try to put it on.
1991 GSX 2.3 Stroker
Old 09-14-2005, 09:16 PM
Re: Re: Exhaust system compatibility
The Megan d/p has a 3in flange. His highflow cat flanges is probably the size of the stock catback. unless it's modified. The best thing to do is buy the 3in catback, and replace the cat with a testpipe and have a matching flange welded to the end of the testpipe to fit the new catback.
Just keep the cat, stock exhaust for emmision testing.
DSM geek
Old 09-15-2005, 01:00 AM
defiancy's Avatar
Re: Re: Re: Exhaust system compatibility
yeah but even though the piping is different sizes the flanges should be the same size. How else would aftermarket catback exhaust bolt up to stock downpipe/cat?
Old 09-15-2005, 09:47 AM
If both the cat and catback have the same stock matching flanges everything would be fine. But, who would want a 2.5in exhaust that reduced to a 2.25in at the flange?? Cut, Weld! IMO
DSM geek
