Old 09-14-2005, 12:12 AM
Hanster24 Hanster24 is offline
Send a message via AIM to Hanster24
Alarm
i have a 96 GST Spyder
amm...i had the top down today, and my frind open the passenger door from the inside, and the alarm went of for about 2-3 min, the it stoped, i couldnt stop it!!!
i tried all combination on my keyless, and it just wouldnt stop!
later on , i unlocked the car "twice", to get something out of the glove box. and the alarm went of, the horn, and the head lights are going on and off. i tried to pop the hood, the trunk, it goes off.!!!!!!
i dont know if i have an aftermarket alarm or what, but i need to be able to use my car!!, only thing i can do is just open the driver door!
96 gst spyder 5 speed
turboxs bov
black in/out + leather
sony speakers + headunit
Old 09-14-2005, 03:03 AM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Re: Alarm
Well then disconnect it. It should be connected to the battery.
1997 Eclipse GSX
Old 09-14-2005, 03:11 AM
Re: Alarm
i dont know were its at? or what it looks like?
turboxs bov
Old 09-14-2005, 06:39 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Alarm
post a few pics of your bay.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 09-14-2005, 07:50 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Alarm
Provided it's the factory alarm, you have to unlock the car with the key using the driver's side door to shut the alarm off.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-14-2005, 08:19 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
That dosn't sound like the factory alarm. Mine goes off if it is armed and you open the door from the inside. but I can turn it off with the unlock button on the keyless pad, or if you put the key in the door and turn it to unlock the alarm goes off immediately.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-14-2005, 02:12 PM
Re: Alarm
i can only get in the car by using the keyless, all my doors are seized up!!
but my keyless unlock works!!, but it doesnt stop the alarm, could the alarm disarm wire be cut or loose or smthing?
turboxs bov
Old 09-14-2005, 02:26 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Re: Alarm
on my sypder if I open the door from the inside with the top down I will set off the alarm. I can only turn it off using the key in the door or the trunk, either works.
If you open the glove box and it goes off thats on the movement sensors, not the key lock sensor. Again you have to use the key in the door/trunk here to disarm it. The only thing I can disarm with my remote is if I hit the panic button on it. And honestly I don't remember how to turn it off..
IF your doors are stuck try your trunk. It will disarm it. The system isn't malfunctioning thats how it works. It may be a little different from the normal eclipses I'm not sure. I don't see why it would be but it could..
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 09-14-2005, 09:58 PM
Re: Alarm
were is the alarm at?
turboxs bov
Old 09-15-2005, 01:32 AM
HiT-TheNos420's Avatar
HiT-TheNos420 HiT-TheNos420 is offline
Re: Alarm
haha, i have this same problem last weak, maybe your battery connection is corroated like mine was. both + and - connection were all white, loosed up both my cnnection by unscrewing it half way-off then I put some anti-corrosion spray on and I dont have the problem anymore, I also disconnected the main power cable thats connected to the negative connect because I fear that was the faulting connect making the alarm go off. good luck. Get those Connections for corrosion.
97' Gs-t, silver, Stock intake & Aftermarket Filter /w stock MAS, 1g BOV /w stock UICP, K&N Oil Filter.....
