Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-13-2005, 10:31 PM
tonyd22 tonyd22 is offline
Question coolant temp. sending unit
i've got an 88 legend c27 5 speed and im trying to put a coolant temp gauge in it but the only sending unit i can find on it is to small for the sensor probe to fit into it. my haynes manual says there is more than one but only tells me where one of them is. the one i found is next to the far end of the upper radiator hose and bleeder valve. any help would be great. thanks
Old 09-13-2005, 11:34 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: coolant temp. sending unit
wheres your stock temperature gauge ?
Team Lonely Drivers
Old 09-14-2005, 09:51 AM
its in the dash but its broken. i broke the needle off about a year ago and i'd probablly put a new one on any way cause i trust auto meter more than a 17 year old stockie anyway
Old 09-14-2005, 01:15 PM
if you want it to fit, you gotta buy an adapter for it, idk what size it is though
Team Lonely Drivers
Old 09-15-2005, 05:24 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
most temp sending units will not tap into hondas small coolant sensor position. you will have to retap into the head. but, if you already have an oem coolant temp sensor, there really is no point in tapping a new sensor in the head. whats important is, if your existing temp gauge still reads whether it is hot or cold.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
