Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 09-13-2005, 09:15 PM
limacina limacina is offline
Wink do your vaccum lines
Last week I replaced all my vaccum lines in about an hour after my oil change. At least the ones I could find under the intake. There was one molded one I had to get from the dealer, otherwise I got everything I needed at Autozone.
Just do them like spark plug wires, one at a time and cut to the length of the old one.
Didn't see anything obvious, though they were in rough shape and it did clear a code a week after doing it.
I didn't get past any of the fittings on the pasenger side near the air filter, maybe someone can suggest failures I should look for over there.
Old 09-13-2005, 10:14 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
did you replace the long one from the underside of intake to the secondary air combi valve at the back of valve cover?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-13-2005, 10:20 PM
Re: do your vaccum lines
There was one long one at the back of the engine running over to the brake booster, I had to make a special trip on that one due to the larger dia. I did see some signs of the old one colapsing there.
There was another long one I did that went from the back of the underside of the intake up and accross the front of the engine and down to bumper level on the passenger side. It sounds like what your talking about. Then 3 or 4 short ones under the intake.
Old 09-16-2005, 09:46 PM
VDUBMAN
What year is your car? if its a 2000+ it should have secondary air. Thats the hose I was talking about. it goes from under the intake manifold on a sensor to the back of the valve cover under the metal pipes.
Old 09-17-2005, 09:07 PM
Oh, yeah 2001.5 Passat 1.8t
I looked under the hood today and I did that line. Thanks for suggesting it though. Just out of curiosity, what does the secondary air system do?
Old 09-19-2005, 06:22 PM
boschmann boschmann is offline
When the engine is cold the O2 sensors are basically off-line & the fuel system is in a default mode, which tends to be set a bit rich. The SAI system is then activated to pump air into the exhaust manifold to aid in more completely combusting any unburned fuel that may be left over.
Old 09-25-2005, 08:34 PM
That answers a lot. When I'm working under the hood and I start the car, I always thought I was hearing a vacum leak, it would go away after a few minutes. Now, I believe, it was the secondary air pump.
Old 10-12-2005, 09:53 AM
katone katone is offline
do you guys know any webpage showing where all these vaccum lines are located?
I got an engine light code P0441 coming out, I wonder if that could be it.
thanks
