Old 09-13-2005, 09:01 PM
knucklescw knucklescw is offline
oil
what kind of oil weight do yall use. i heard to use something like 20w-50. is this correct?
Old 09-13-2005, 09:32 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: oil
0w-30 or 5w-30
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 09-13-2005, 10:34 PM
TMD TMD is offline
Re: oil
I am using 20/50 right now to help combat the leaking valve guide seals. I will soon switch over to 25/40 Mercury oil as it exceeds many brands on the market and is specifically meant for high reving engines.
But...as TSG says....those are the proper ones to be using.
TMD
Old 09-14-2005, 07:50 PM
Hotshot8792 Hotshot8792 is offline
i use Mobile 1 synthetic 15W-50. Apperantly some 10 and 11 second 3SI members use this as well, and like me, haven't spun a bearing yet, so its a great oil to use IMO.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 09-21-2005, 08:10 PM
Re: oil
thanks hotshot bought the mobile 1 synthetic 15w-50. runs alittle better and my lifters sound so much quiter. thanks!!!!!
Old 09-22-2005, 12:21 AM
AutostradaVR4 AutostradaVR4 is offline
Re: oil
what would be the downfall of running say 10-30???
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 09-22-2005, 12:02 PM
2old 2old is offline
Re: Re: oil
Withoug getting onto organic chemistry in general, oil gets thinner the warmer it gets. The second number indecates what vicosity the oil has at 100 degrees celsius (ie: 30 weight oil for 10w30 or 50 weight oil for 10w50).
The vicosity is important because it determines the thickness of on the oil film when the engines are warmed up and running... Running a lighter oil means a thinner oil film.
10w30 is fine for NA engines but for turbo engines you will need a thicker oil for 2 reasons:
1) it provides a thicker oil film so that when that piston is forced down on the crackshaft there is more "custion" between the parts before you get metal on metal contact
2) Turbos run really hot and the oil has to be more heat resistant in order to lubicate it properly.
You can run 10w30 on a turbo with no side effects but you are lowering your factor of safety (sort of like driving a car with no insurance)...
Old 09-23-2005, 02:43 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: oil
20W-50 what I always run...if I buy the high mileage not cheap stuff + some engine flush I get no lifter ticker for 3000 miles.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-23-2005, 01:25 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: Re: oil
so what does 1st number indicate?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-23-2005, 01:43 PM
Re: Re: Re: Re: oil
The 1st number indecated the "weight" or the oil at 0 degrees celcius. (IE: 10w30 the oil reacts like a 10 weight oil at 0 Degrees celcius and a 30 weight oil at 100 Degrees celcius)
So the 2 numbers combined indecate how flat the viscosity curve is over the temperature range.
Just so no-one comes to the conclusion that 5w50 is better then 10w30 in general the flatter curve the more viscosity modifiers that the oil company needed to add to the oil. The Viscosity modifiers are less stable then the oil stock it has been added to, and therefore more prone to thermal breakdown.
Old 09-23-2005, 08:43 PM
Re: oil
finally a straight answer on what those numbers mean...i'll have to read it a few times to get it for sure....but at least its there! thx 2old!
Old 09-23-2005, 09:24 PM
Re: oil
alright, trying not to sound like a moron or annoy anyone, but i am still a little confused. What oil should i put in my VR4 for the best protection?
Formerly BlinkRA182
Old 09-23-2005, 10:32 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: oil
i have heard some bad stories bout mobile 1 an what not.... It swells up the seals an all - an when or if by any chance u ever put a different oil in its a high danger to the engine for stuff to spin wrong break, or throw on the engine.... i just use a non-synthetic (castrol gtx in all my cars an never had a problem) drive hard!
lol
btw thanks for the oil lesson 2old very cool of u to take the time to do that for all of us thumbs up!
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 09-24-2005, 10:51 AM
Re: Re: oil
It's simple really... It's all about temperature and how often you change your oil... IE:
Drive your car short distances in Boston in the middle of winter: 5w30
Drive your car long distances in Phoenix in the middle of summer: 20w50
Drive you car through any temperature and any length and change your oil pretty religiously: 5w50
Don't really like to be bothered to change your oil: 10w30
That is why the owners manual has those weird charts... The thinner the oil the better the start up protection, but the thinner the oil film when the oil is warm so less lubrication when the engine is pushed hard.
The bigger the range the range the more tolerant it is to different driving conditions but the oil has to be changed more often because it breaks down faster...
So "best protection" depends on how you define protection.
Old 09-24-2005, 11:08 AM
Re: Re: oil
This is one of those "car urban myths" that is kindof-sortof true but for the wrong reasons...
In the 1970-80s they had problems with synthetic reacting with the rubber used to seal engines of that era but 2 things happened: Oil company reformulated the oil not to react with the seals and the car companies stopped using rubber to seal things.
That said, synthetic oils have a lot more detergent added to the oil then conventional oil so if you even think your engine has a oil leak, using synthetic will make it worse.
But if you are pretty sure that your engine does not have a oil leak it will not cause an oil leak and will clean up the gunk left in your lash adjustors which eventually gets rid of the dreaded tick.
