Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 09-13-2005, 08:11 PM
laser16b laser16b is offline
89 daytona - despertly need help
i have a 1989 daytona, non turbo 4 cylinder...5-speed
when you start it it starts and then shuts right off, it will start right back up and shut off again...you can do this all day...
i have replaced
O'2 senser
T.B. pressure reg.
fuel pump and sock
T.B temp senser
fuel filter
TPS
mapp senser
EGR vavle was checked and is ok
ive checked all wireing connectors, unpluged and repluged everything
checked all vacume hoses
when it starts it runs mabey 2 seconds and the motor sounds fine...it just shuts it self off...
im at a loss as to what to do now... .anybody got any ideas....
Thanks
Old 09-13-2005, 08:37 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
Re: 89 daytona - despertly need help
get a timing light and check the timing... or it could be bad gas in the car, do the timing...no luck, drain the gas and put new gas in, that dont do nething, then do a TUNE-UP
Old 09-13-2005, 08:54 PM
tuneup was the first thing i did, and i drained the gas when i put the fuel pump in
Old 09-16-2005, 11:13 AM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
ya your timing could be off- but you could have a bad ground - or not gettin efficent spark, check your wires an harness... ect...
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 09-20-2005, 12:24 AM
ok spent the day testing stuff and cleaning...i found the grounding block...behind the batt...removed all rust and stuff...unpluged and checked all plugs behind batt...checked all sencers for a short and found none..checked distribtor..its spotless...checked if jumped time...it did not...stright wired the car to see if it would stay running....i dont think it works on this car
could it be the computer on the drivers side under the hood...how would i go about testing it to find out?
thanks for all your input so far....this thing is killing me!!
Old 10-05-2005, 11:42 AM
89ltd 89ltd is offline
check auto shut down relay and fuel pump relay.
Old 10-05-2005, 07:22 PM
92dksdaytona 92dksdaytona is offline
Send a message via AIM to 92dksdaytona Send a message via MSN to 92dksdaytona Send a message via Yahoo to 92dksdaytona
check your fuel pressure regulator.
Old 10-23-2005, 02:35 AM
Tamerlane Tamerlane is offline
i have replaced
O'2 senser
T.B. pressure reg.
fuel pump and sock
T.B temp senser
fuel filter
TPS
mapp senser
Thanks
Had the same thing happen to me. My car had 180k miles on it, no problems like that one. But one day went to get a hamburger at a drive through. Turned the engine off for a few minutes while waiting then when I went to turn it on it ran for a few seconds, like two and the just shut off. I suspected the shutdown relay, but I had recenlty changed it. Had the car towed home.
The next day I shorted the shutdown relay to see if the car would keep running still nothing. I even changed the fuel injectors, expensive step and the fuel pressure regulator, still nothing.
Guess what it was???? Had an old engine controller sitting around, plugged it in and it ran fine.
Go figure. Since then I have been to the pick a part and picked up a few extra controllers for 30 bucks each. My car is a v6 3.0 engine, but I suspect that whatever computer failure causes this is problem prone to happen in the 4 cyn engines as well
Good luck! I figure, well now I have new injectors and a new regulator?
But check the fuel pressure and make sure that it is good as well.
Good luck!!!
